Results 1 to 4 of 4
Thread: Copy Excel Sheet
    Member ScubaMan's Avatar
    July 6, 2015
    201
    03:57 PM
    Copy Excel Sheet
    Hello all,
    Do any of you know if its possible to copy an excel sheet using dynamo. I know you can copy an excel file but I want to copy a sheet that has been pre-formatted.
    Thanks,
    February 2, 2011
    Montreal/Paris
    830
    05:57 PM
    The only way i know to enter Excel data and format it is to use Bumblebee
    July 6, 2015
    201
    03:57 PM
    Ya that is what I was thinking. I have a script that copies a template file and adds the data. It works great but I need to have 5 separate excel files. I was hoping to be able to copy the preformed sheet.
    Thanks for the reply DanielHurtubise,
    February 2, 2011
    Montreal/Paris
    830
    05:57 PM
    If the Excel file is only about formatting then you can specify where to enter the data very precisely though.
    Or dump in batch in a tab and use Excel Pivot Table to fill out your template
  1. Copy Sheet Between 2 Projects
    By dbzn in forum Architecture and General Revit Questions
    Last Post: June 7th, 2017, 08:57 AM
  2. Import an Excel Sheet into a Revit family
    By Pavan1509 in forum Structure - Family Creation
    Last Post: October 4th, 2016, 10:26 PM
  3. Import an Excel Sheet into Revit family
    By Pavan1509 in forum Third party Add-Ins, API and R&D
    Last Post: September 28th, 2016, 05:36 AM
  4. Replies: 0
    Last Post: March 2nd, 2015, 12:15 PM
  5. Replies: 0
    Last Post: November 25th, 2014, 09:45 PM
