Results 1 to 6 of 6
Like Tree4Likes
  • 1 Post By cellersick
  • 2 Post By Yna_Db
  • 1 Post By amoursol
Thread: Boolean OR for list
    Member ScubaMan's Avatar
    July 6, 2015
    199
    06:45 AM
    Boolean OR for list
    Hello all,
    Logic / Action / or you can insert any number of booleans and it will pass true if any of them are true. Is there a way to do this with a list of booleans rather than just one. You can use || for two list but what if I want more. Always more!
    Thank for you help,
    Steven
    March 21, 2013
    Phoenix, AZ
    275
    06:45 AM
    How about something like this? Create your list and transpose so that the sublists are the "answers" for each item, then ask if any members of the sublist contain TRUE:
    Attached Thumbnails Attached Thumbnails Boolean OR for list-multiple-bool.png
    ScubaMan likes this.
    July 6, 2015
    199
    06:45 AM
    Thats a great solution. Thank you Cellersick. It would be nice if OR would work on list but what you said will work for now.
    September 19, 2015
    163
    02:45 PM
    You can use || instead, also in a code block
    Attached Thumbnails Attached Thumbnails Boolean OR for list-multiple-entries.jpg   Boolean OR for list-multiple-entries.jpg
    amoursol and ScubaMan like this.
    November 21, 2012
    London, United Kingdom
    612
    02:45 PM
    As mentioned by Yna_Db this is the Code Block version!
    Attached Thumbnails Attached Thumbnails Boolean OR for list-revitforumquery_or.jpg
    July 6, 2015
    199
    06:45 AM
    Thanks guys those are all great ideas.
  1. Replies: 0
    Last Post: November 7th, 2014, 10:45 AM
  2. Boolean Expression Error
    By Gabriel Black in forum MEP - Family Creation
    Last Post: March 12th, 2014, 07:30 PM
  3. Improper use of Boolean Expression message with my calculated value formula
    By sippel26 in forum Architecture and General Revit Questions
    Last Post: February 13th, 2014, 07:20 PM
  4. Building Coder: Boolean Operations for 2D Polygons
    Last Post: September 2nd, 2013, 09:15 AM
  5. Frustrations with simple boolean expression
    By LarsBjoern in forum Architecture and General Revit Questions
    Last Post: June 10th, 2013, 07:40 AM
