Results 1 to 10 of 10
Like Tree6Likes
  • 1 Post By cellophane
  • 1 Post By amoursol
  • 1 Post By ScubaMan
  • 2 Post By cellophane
Thread: Titleblock Locations
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,104
    12:20 PM
    Somehow my titleblocks are wonky and are not all located at the same origin, meaning I can't copy aligned to sheet without having to do a lot of manual fixing. Is there a way to set the titleblock locations to all be the same? I can pull the titleblock X, Y & Z location but can't figure out how to reset that...
    Attached Thumbnails Attached Thumbnails Titleblock Locations-titleblocklocation.png
    omerhhh likes this.
    Gold Coast
    2,601
    02:20 AM
    Just did a bit of searching on my phone, apparently theres an Element.SetLocation (or something like that) node.
    November 21, 2012
    London, United Kingdom
    612
    05:20 PM
    If SetLocation doesn't work, you could simply generate a Vector.ByTwoPoints, with the origin being one point, and your GetLocation being the next, reverse the vector and simply translate the family back
    cganiere likes this.
    August 9, 2011
    Louisville, KY
    6,104
    12:20 PM
    I had tried Element.SetLocation yesterday and didn't have much luck. Did some googling on it and found this thread: https://forum.dynamobim.com/t/spring...orking/8930/10 - in particular Jacob's response about the Element Has Location function and the reply afterwards about the API. Seems you can set it through the API but that is way over my head... Anyone know how to do that?
    Attached Thumbnails Attached Thumbnails Titleblock Locations-titleblockelementlocation.png
    Member ScubaMan's Avatar
    July 6, 2015
    199
    09:20 AM
    Hey Cellophane,
    I am the one who started the dynamo forum post. I never found a way to move a reference point.
    I have however moved title blocks. I am guessing the three title block location you have are all from different title blocks?
    I created a script to place things on sheets. I ran into a problem that all of our title block were in slightly different location. I tried to subtract the difference from the origin but it was off by a smaller amount than 1/256" and Revit would not deal with it. Long story short I moved all of the title block to the origin in the family.
    I used dynamo to draw a line from 0,0 to some point. I then manually moved the title block (in the family) to the end of the line at 0,0. They were easy to move since you can just select everything and move it all together.
    This will shift every title block in your project. so it could mess up every sheet depending on how you have them set up.
    Hope this will help you. If you have any question please ask. Your post have helped me a great deal over the years.
    Steven
    August 9, 2011
    Louisville, KY
    6,104
    12:20 PM
    Thanks Steven.
    The problem I'm running into is that I moved the title block origin in the family and reloaded, which shifted them in the project. Some were adjusted to be fixed, some were adjusted but by an incorrect value (??) and some are where they loaded in initially. I'd prefer not having to manually go through every sheet if possible...
    July 6, 2015
    199
    09:20 AM
    Oh sorry you are one step ahead of where I thought you were.
    Are you looking for a way to reposition all of your title blocks in the project after you reload the moved family?
    If so do you know the distance each family moved or are you trying to move each title block to 0,0 in the sheet view?
    I just did a test run and it seams to have worked for me. see image
    Attached Thumbnails Attached Thumbnails Titleblock Locations-capture2.png   Titleblock Locations-capture3.png
    August 9, 2011
    Louisville, KY
    6,104
    12:20 PM
    I'm a moron. I was lacing from the Element.GetLocation node instead of the All Elements of Category node
    Thanks for the assist!
    ScubaMan and amoursol like this.
    July 6, 2015
    199
    09:20 AM
    I think we have all be there before. Glad I could assist.
    August 9, 2011
    Louisville, KY
    6,104
    12:20 PM
    Necroposting. woo! Just wanted to add the graph.
    Attached Files Attached Files
    amoursol likes this.
  1. Keynote file locations
    By dtp81390 in forum Architecture and General Revit Questions
    Last Post: June 20th, 2017, 03:55 PM
  2. BIM Opportunities - Various Locations
    By Jonojnr in forum Career Corner
    Last Post: May 22nd, 2015, 03:23 PM
  3. Family Locations
    By ESD ltd in forum Architecture and General Revit Questions
    Last Post: November 14th, 2014, 05:26 PM
  4. Locations of Equipment
    By domsib in forum MEP - General
    Last Post: April 12th, 2013, 03:27 PM
  5. Collaborate via in internet 2 locations
    By precast100 in forum Worksharing, Revit Server & C4R
    Last Post: January 16th, 2012, 02:27 PM
