Results 1 to 8 of 8
Like Tree12Likes
  • 2 Post By GMcDowellJr
  • 2 Post By ryntau
  • 4 Post By amoursol
  • 1 Post By Yna_Db
  • 1 Post By Yna_Db
  • 2 Post By ryntau
Thread: Swapping out Curtain Panels
    Member ryntau's Avatar
    October 11, 2012
    St. Louis
    401
    03:45 AM
    I wondering if this is even possible. I have a Curtain wall with a regular grid, 20 wide by 9 tall. I have 18 different curtain panels that i'd like to place in this curtain wall following certain rules. Is it possible to swap out panels for my custom panels using corresponding cells in Excel?
    or is there a different approach i should be looking for?
    I've attached a couple of images
    Thanks,
    Attached Thumbnails Attached Thumbnails Swapping out Curtain Panels-dynamocurtain02.png   Swapping out Curtain Panels-dynamocurtain01.png
    December 21, 2010
    Phoenix, AZ
    2,556
    03:45 AM
    Simply put, yes. Several plugins will do this as will Dynamo.
    Sent from my iPad using Tapatalk
    amoursol and cganiere like this.
    October 11, 2012
    St. Louis
    401
    03:45 AM
    at its most basic, here's the graph. i think it's just a matter of parsing down the list of panels now.
    Attached Thumbnails Attached Thumbnails Swapping out Curtain Panels-curtainpanelswap.png
    November 21, 2012
    London, United Kingdom
    612
    11:45 AM
    Hello Ryan,
    So you're going to run into one or two problems. Namely, paring the structure of your Excel with the actual panels. But it's all solvable.
    I've re-created your example in my own way as follows:
    I've generated 100x shuffled Types of panel I want to match. In this case, they are also colour coded.
    I want to pair each one within Revit as it appears in Excel. To do so, we need to check if the way in which the panels are sequentially built in Revit matches our system.
    I bring through my excel data (Which is just text) and flatten off the listings (As the Curtain panels are a flat list).
    I then simply use them as a Key when I'm pairing my panels through the List.GroupByKey method.
    As my families are called the same thing as my keys, I can simply use FamilyType.ByName to pull them from the Revit document. If you'rs are different, you'll simply have to create a list of them based around your key list structure.
    This gives me the following results:
    However, the way the Curtain Panels have been generated doesn't quite match my colour scheme in Excel. So I need to fix my panels first.
    What I want is to find out how they panels appear in the list. If I use a simple colour override and pick elements of a full line and one additional, I can see how this builds:
    This is showing that my first line is running along the base, then it starts back at the same place, but one line above. You can test this by changing the designscript format.
    So what we need to do, is chop up our list using List.TakeEveryNthItem, transpose said list, reverse the sub-groupings and then reverse the entire outer list... rather convoluted I know
    But it does give us our result!!
    Attached Thumbnails Attached Thumbnails Swapping out Curtain Panels-revitforumquery_01.jpg   Swapping out Curtain Panels-revitforumquery_02.jpg   Swapping out Curtain Panels-revitforumquery_03.jpg   Swapping out Curtain Panels-revitforumquery_04.jpg   Swapping out Curtain Panels-revitforumquery_05.jpg
    Swapping out Curtain Panels-revitforumquery_06.jpg   Swapping out Curtain Panels-revitforumquery_07.jpg   Swapping out Curtain Panels-revitforumquery_07.jpg   Swapping out Curtain Panels-revitforumquery_08.jpg   Swapping out Curtain Panels-revitforumquery_09.jpg
    Yna_Db, cganiere, ryntau and 1 others like this.
    September 19, 2015
    163
    11:45 AM
    Another approach to make lists match could consist in classifying the panels by their coordinates.
    amoursol likes this.
    November 21, 2012
    612
    11:45 AM
    Quote Originally Posted by Yna_Db View Post
    Totally! The problem with geometrical methods is they get heavy, and you can't use Element.GetLocation on Curtain Panels If you have to pull Element.Geometry it get's nasty the bigger the panels are.
    September 19, 2015
    163
    11:45 AM
    You can still use the elements bounding boxes min points, it shouldn't be too heavy to manipulate...
    October 11, 2012
    St. Louis
    401
    03:45 AM
    this is the way i approached it, i'm sure there is some consolidation that could take place. this is also assuming that the number of panels in the x and y direction don't change.
    Edit: i've also chopped it down a bit, i have 19 panels to choose from, not just the 4 shown here.
    I think your Keys approach will allow me to make it much simpler
    cganiere and amoursol like this.
  1. void for curtain panels does not cut
    By spotless in forum Architecture and General Revit Questions
    Last Post: November 15th, 2018, 08:19 PM
  2. missing curtain panels
    Last Post: June 2nd, 2015, 07:08 PM
  3. Problem with adding custom curtain wall panels to curved curtain wall.
    By aktaylorh in forum Architecture and General Revit Questions
    Last Post: November 20th, 2013, 07:16 PM
  4. Curtain wall panels
    By Bradscott in forum Architecture and General Revit Questions
    Last Post: February 8th, 2013, 01:26 PM
  5. Custom Curtain Panels
    By MikeMaloney in forum Architecture and General Revit Questions
    Last Post: January 9th, 2011, 03:09 PM
