Results 1 to 7 of 7
Like Tree3Likes
  • 2 Post By DanielHurtubise
  • 1 Post By amoursol
Thread: Change Level of a Space
    October 6, 2012
    10
    05:22 PM
    Hi all,
    I'm trying to change the Level of the Space to another Level but it seems that i'm doing something wrong.
    I read all the Built in Parameters with regarding "Level" of the Spaces but still doesn't work.
    Anyone can help me?
    Thanks
    Attached Thumbnails Attached Thumbnails Change Level of a Space-screenshot_3.jpg   Change Level of a Space-screenshot_4.jpg
    February 2, 2011
    Montreal/Paris
    830
    11:22 AM
    Using the UI you can't either. Rooms and Spaces have the Level property read only so i dont think you can change them using Dynamo by just changing the level.
    The way to do it with the UI is to Cut and Paste to a new Level. Same would work with Dynamo
    amoursol and duende123 like this.
    October 6, 2012
    10
    05:22 PM
    Thanks for reply, sure i tried it first in Revit but it seems when you have 2 different Name Levels with the same elevation and you cut and paste all those spaces they paste at the same level (incorrect one) not the good one.
    I have two Level Names "(dont use)LEVEL 00" and "00_Groundfloor" if i cut all the spaces in the "dont use level" and paste in a new floor plan view associated with "00_GroundFloor" they paste again at "dont use level"... its so annoying.
    Thanks.
    November 21, 2012
    London, United Kingdom
    612
    05:22 PM
    Hello S Ramirez,
    To generate spaces, it's as simple as the following graph. This will generate New Spaces, so you'll have to assign the information over from the originals after the fact (Then simply delete the originals).
    Attached Thumbnails Attached Thumbnails Change Level of a Space-revitforumquery_mep_spaces.jpg
    cganiere likes this.
    November 21, 2012
    612
    05:22 PM
    As an addendum (And note, I haven't tested this), this could be one way of you going about said mapping:
    In theory, if the parameter is read only, it should simply fail. If you want to be good about it, you can add the read-only ones into the Filter.
    Attached Thumbnails Attached Thumbnails Change Level of a Space-revitforumquery_mep_2.png
    September 19, 2015
    163
    05:22 PM
    Grouping spaces before copy-pasting on a selected level through the clipboard and then ungroup seems to work (as well as the workflow described for rooms here: https://forum.dynamobim.com/t/change...cement/14392/4)
    October 6, 2012
    10
    05:22 PM
    Very grateful. It works. Cool
    I got it. Thanks!
  1. is there a way to change the name of level in schedule only ?
    Last Post: July 31st, 2017, 01:39 PM
  2. Pipe schedule by level and space....
    By Brocha in forum MEP - General
    Last Post: August 6th, 2015, 02:39 PM
  3. How to use the Parking Space Components in the Upper Level Floors?
    By littlebear in forum Architecture and General Revit Questions
    Last Post: May 29th, 2014, 04:08 PM
  4. Space tags on multiple of same level - View Templates or not
    By domsib in forum Architecture and General Revit Questions
    Last Post: July 11th, 2013, 10:45 AM
  5. can't change sill level
    By archz2 in forum Architecture and General Revit Questions
    Last Post: July 19th, 2012, 07:48 AM
Tags for this Thread
