Results 1 to 7 of 7
Like Tree4Likes
  • 2 Post By amoursol
  • 1 Post By WVReviter
  • 1 Post By amoursol
Thread: Revit <--> Excel
    January 10, 2011
    61
    11:35 AM
    Unhappy Revit <--> Excel
    Dynamo gurus:
    I am just getting started, so please forgive my ignorance. I have managed (mostly using Data-Shapes) to cobble together a way to export room parameters to Excel, along with the ID of each room object.
    My challenge is to re-import once the Excel has been filled out. The problem is associating the data in each line with the ID. If a room has been deleted since the Excel export or a cell has been left blank, it throws a null value. This, in turn, throws off the number of items in the final list.
    Any suggestions on keeping the data in each row associated with the ID would be appreciated!
    Thanks,
    RL
    November 21, 2012
    London, United Kingdom
    612
    05:35 PM
    Kia ora RL,
    Please have a look at my blog post WRANGLE THAT DATA: DYNAMO FILTRATION AND SORTING - Design Tech, specifically the Get Keys method as it will do exactly what you're after
    Andres Franco and ryntau like this.
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,104
    12:35 PM
    Quote Originally Posted by amoursol View Post
    Kia ora RL,
    Why do you use the == node into your Filter.ByBoolMask node?
    FWIW - I can never get the stupid bool filter to work the way I think it should - perhaps because I don't use the == node?
    November 21, 2012
    612
    05:35 PM
    == is simply a comparison. Does A equals B? If so it spits out true, if not it spits out false. I use it as the basis for almost all of my List.FilterByBoolMask filtration. It's extremely powerful in conjunction with the Get Keys workflow in the link for processing an Element ID check of data (Even better with GUID).
    January 10, 2011
    61
    11:35 AM
    Thanks! I will give this a try and report back...
    Reuben
    amoursol likes this.
    January 10, 2011
    61
    11:35 AM
    Sol:
    Sorry to be so thickheaded here, but I couldn't figure out how to get this to work using GetKeys. I used the List.ContainsItem to parse through the list and make a new list based on whether the room still exists. Then I passed this info on to a List.Transpose node to make lists that I use to populate parameters. (see image) Do you think this method will cause any problems, or is the GetKeys method way more reliable?
    Thanks for your help!
    Reuben
    Kia ora RL,
    November 21, 2012
    612
    05:35 PM
    List Get Keys method will allow you to use any jumble list versus any other jumbled list.
    In your example, you're hard coding in some queries (i.e GetItemAtIndex to 7), which is great in an isolated case, but may fall flat if your data structure changes.
    In essence, for robustness of script, you want to avoid hard-coding as much as possible
    uaifestival likes this.
  1. Revit To Excel
    By veeranna.guggari13 in forum Dynamo BIM
    Last Post: February 9th, 2016, 09:58 AM
  2. Renaming From Excel - After Sorting Data in Excel
    By cellophane in forum Dynamo BIM
    Last Post: January 18th, 2016, 02:24 PM
  3. Revit to Excel and Excel to Revit
    By yogihit in forum Dynamo BIM
    Last Post: October 13th, 2015, 01:23 PM
  4. Replies: 3
    Last Post: June 6th, 2015, 11:18 AM
  5. Excel to Revit
    By trohman in forum MEP - General
    Last Post: December 22nd, 2014, 02:27 PM
