Results 1 to 3 of 3
Like Tree2Likes
  • 2 Post By ryntau
Thread: Pushing data to rooms from Excel
    Member ryntau's Avatar
    October 11, 2012
    St. Louis
    403
    08:20 PM
    I think the list.map node is what i want for the situation outlined below, i'm just having trouble getting my head wrapped around it and was looking to see if anyone has some direction that i could take and learn from.
    Basically, i have a project with say 100 rooms and the ground floor. Most of these rooms have a unique identifier (room number). There is an Excel file that has a giant list of all the rooms, their number, programmed area, occupancy, department. I'd like to push all of that data into the revit model, but am hitting some road blocks because the number of rooms don't exactly match, and i haven't found a way to use the room number as a key that links them together. my limited knowledge of the list.map node makes me think it is the right track, but i can't seem to figure it out. any pointers?
    September 19, 2015
    163
    04:20 AM
    A Dictionary is probably what you need. This could help for a start:
    https://forum.dynamobim.com/t/search...ther-list/7935
    October 11, 2012
    St. Louis
    403
    08:20 PM
    This is exactly it, thank you. I'll publish my graph as soon as i get it cleaned up.
    Yna_Db and amoursol like this.
  1. Creating rooms using an excel file
    By Jorgensen in forum Dynamo BIM
    Last Post: March 30th, 2016, 08:21 AM
  2. Renaming From Excel - After Sorting Data in Excel
    By cellophane in forum Dynamo BIM
    Last Post: January 18th, 2016, 01:24 PM
  3. Import data from excel
    By rdon in forum MEP - General
    Last Post: August 21st, 2015, 12:52 PM
  4. Replies: 0
    Last Post: July 11th, 2014, 01:45 PM
  5. Label/tag using excel data
    By arthurhr in forum Architecture and General Revit Questions
    Last Post: February 19th, 2014, 06:26 PM
