Results 1 to 7 of 7
Like Tree4Likes
  • 1 Post By GMcDowellJr
  • 2 Post By Twiceroadsfool
  • 1 Post By elton williams
Thread: Any way to prevent "divide by zero" from locking up Dynamo entirely?
    Member PatrickGSR94's Avatar
    July 7, 2017
    Hernando, MS
    492
    01:18 PM
    Doing some tutorials right now where I have a code block that divides x by y. For the Y input I have a number slider. I've run into the problem of accidentally moving the slider to zero, with Dynamo set to Automatic, locks up the program completely. I have to shut it down, shut Revit down, everything, and then open up everything again. Why doesn't it just give an error message or something?
    July 7, 2017
    Hernando, MS
    492
    01:18 PM
    Oh okay I found the "Minimum" value field underneath the slider. Still it seems weird that divide by zero would lock up the whole thing instead of just generating an error, like a red node or something.
    December 21, 2010
    Phoenix, AZ
    2,603
    11:18 AM
    Might be the node you're using. I just did a bunch of division, some by zero, and didn't lock up. Instead I get NaN (Not a Number).
    amoursol likes this.
    July 7, 2017
    Hernando, MS
    492
    01:18 PM
    Quote Originally Posted by GMcDowellJr View Post
    I just used a regular number slider, and connected it to a Code Block with "x/y" as the code, number slider connected to the Y input. Several other nodes went into the X input.
    10,198
    01:18 PM
    Hehehe. Welcome to Dynamo. A ton of stuff will shag dynamo or make Revit crash. I almost never leave it on automatic.
    Aaron Maller
    Director
    Parallax Team, Inc.
    elton williams and amoursol like this.
    Gold Coast
    2,621
    04:18 AM
    I just wish it was set to manual by default for new scripts bc i keep forgetting to switch it and after the first few nodes get connected....
    November 21, 2012
    London, United Kingdom
    612
    07:18 PM
    I think I'm one of the only folk who actually likes automatic... that being said, I do turn off any heavy-duty scripts to Manual pretty swiftly
  1. Replies: 4
    Last Post: August 2nd, 2017, 02:30 PM
  2. Replies: 0
    Last Post: April 5th, 2017, 08:45 AM
  3. Replies: 1
    Last Post: August 30th, 2016, 04:00 PM
  4. Replies: 8
    Last Post: March 21st, 2016, 11:53 AM
