Results 1 to 3 of 3
Thread: Perforated Brick Walls
    Lox
    Lox is offline
    April 4, 2013
    Christchurch, New Zealand
    157
    01:50 AM
    Hi all,
    Can anyone point me in the direction of a Dynamo tutorial for a perforated brick wall, I am wanting a perforated brick wall which curves around and out forming a cone like form. I am a Dynamo newbie but keen to learn, or is this possible to do within Revit? Any suggestions would be greatly appreciated?
    Thanks all,
    Lox
    Gold Coast
    2,602
    10:50 PM
    Totally doable in revit with massing and adaptive components/ curtain panels. If you want a moee programmitc approach you could use dynamo.
    November 21, 2012
    London, United Kingdom
    612
    01:50 PM
    Could you provide a quick sketch of what you want do do?
  1. How to make the texture of brick walls (or other types)continues on a joined wall????
    By margi85 in forum Architecture and General Revit Questions
    Last Post: June 23rd, 2017, 01:17 PM
  2. Perforated walls
    By lallanji in forum Architecture - Family Creation
    Last Post: August 27th, 2014, 05:07 PM
  3. Brick walls + wrapping plaster, THEN partition walls (gypsum boards with metal const)
    By turuly in forum Architecture and General Revit Questions
    Last Post: July 21st, 2014, 06:44 PM
  4. modeling a brick wall ( brick by brick)
    By Andrew P in forum Architecture and General Revit Questions
    Last Post: April 1st, 2013, 03:50 PM
  5. Walls - Masonry offset to a brick ledge
    Last Post: November 17th, 2011, 06:30 PM
