Results 1 to 3 of 3
Thread: Batch deleting worksets
    January 27, 2017
    39
    08:21 AM
    Hello,
    I am merely a beginner with Dynamo, and we are trying to automate everything related to workset creation/editing/deleting/managing them.
    So far we have scripts to create worksets from excel files, assign elements to worksets, and now what we need is a script to delete all unused worksets.
    I could not find anything online about it, and I don't really know where to start with it.
    Does anybody have a script or some idea on what would be the best way to do this?
    May 3, 2012
    1,403
    10:21 AM
    If you install the "ArchiLab" package, it contains Get all Worksets and Delete Element nodes.
    Edit: (Ah, I see. Just reading on the DynamoBIM forum and deleting worksets is not possible via API.... They do not behave like other elements. You can probably find a way to check which worksets are empty and rename them though, so its obvious what you need to manually delete)
    Junior Member PolynineStudio's Avatar
    April 25, 2017
    31
    03:21 AM
  1. deleting parameters...
    By sorati22 in forum Structure - General Questions
    Last Post: May 31st, 2015, 11:57 AM
  2. Revit OpEd: Deleting a Workset and Open Worksets
    Last Post: July 8th, 2014, 05:16 AM
  3. Worksets - recombining to central file and deleting local files
    By ronario81 in forum Architecture and General Revit Questions
    Last Post: October 15th, 2013, 03:04 PM
  4. deleting grids = deleting what else?
    By lost again again in forum Architecture and General Revit Questions
    Last Post: August 28th, 2013, 11:56 PM
  5. deleting import
    By imsureakoto in forum Architecture and General Revit Questions
    Last Post: September 6th, 2012, 03:32 PM
