Page 1 of 2 12 LastLast
Results 1 to 10 of 12
Like Tree12Likes
Thread: "disallow join" via dynamo
    November 18, 2013
    Germany
    103
    04:08 AM
    Hello,
    It seems to be so simple...!
    I would like to put all my start and endpoints of my walls to "disallow Join"
    How the hell get I fixed that? It is easy to select the walls. How can I catch the properties via dynamo to change it.
    Manually it is just a right-click to a menu...
    ...how can I catch it with dynamo?
    I am glad about any advise, or a small .dyn script
    KR
    Andreas
    Attached Thumbnails Attached Thumbnails "disallow join" via dynamo-auswahl-der-wand.jpg   "disallow join" via dynamo-verbindung-nicht-zulassen.jpg
    Attached Files Attached Files
    November 21, 2012
    London, United Kingdom
    612
    05:08 AM
    Hello Andreas,
    The following graph will do what you require
    They Python code is as follows:
    [Allow Joins]
    [Disallow Joins]
    Attached Thumbnails Attached Thumbnails "disallow join" via dynamo-revitforumquery_allowdisallowjoins.jpg   "disallow join" via dynamo-revitforumquery_allowpython.jpg   "disallow join" via dynamo-revitforumquery_disallowpython.jpg
    November 18, 2013
    Germany
    103
    04:08 AM
    Talking Errors
    Hello,
    Thank you very much! for this straigt help!
    In spite of that, I have still some trouble:
    I rebuilt your Tree and the pyton script, but I get errors
    Script:
    import
    clr
    clr.AddReference('RevitServices')
    import RevitServices
    from RevitServices.Persistence import DocumentManager
    from RevitServices.Transactions import TransactionManager
    clr.AddReference('RevitAPI')
    from Autodesk.Revit.DB import WallUtils
    doc = DocumentManager.Instance.CurrentDBDocument
    Walls = UnwrapElement(IN[0])
    success, failure = [],[]
    for wall in walls:
    try:
    TransactionManager.Instance.EnsureInTransaction(do c)
    WallUtils.AllowWallJoinAtEnd(wall,0)
    WallUtils.AllowWallJoinAtEnd(wall,1)
    TransactionManager.Instance.TransactuinTaskDone()
    success.append(wall)
    except:
    Failure.append("Failure: Element category" +str
    (wall.Category.Name))
    OUT = (Success,failure)
    Attached Thumbnails Attached Thumbnails "disallow join" via dynamo-disallow_.jpg   "disallow join" via dynamo-error_1.jpg   "disallow join" via dynamo-error_1.jpg
    November 21, 2012
    612
    05:08 AM
    Use 'l' (The letter), not '1' (The number) in the Count
    When you are doing the code, you need to pay a lot of attention to Capitalisation and indentation.
    The error is because you have capitalised one 'Walls' and not the one in the following line:
    for wall in walls:
    If you go back and uncapitalise one - or capitalise the other - it should work. Please go over my code line by line and it should be fine!
    cganiere, uaifestival and Mengelmn like this.
    November 18, 2013
    Germany
    103
    04:08 AM
    it worked
    Thank you! So it worked!
    in both directions
    amoursol likes this.
    November 18, 2013
    Germany
    103
    04:08 AM
    API list
    Is there a list of all API utils
    Can I import everthing f.e. floor.utils ... door.utils...
    Is there a forum for API programming?
    Is there maybe literature?
    I did just the "Code Academy" regarding Python
    KR
    Andreas
    November 21, 2012
    612
    05:08 AM
    Not that I've found yet sorry, but you can use
    revitapidocs.com
    and search for things If you simply use the keyword 'utils' it should pop up things.
    Download the Revit SDK (Software Development Kit) and use that in conjunction with the website above.
    There is a Revit API forum, but I don't really use it (As my focus is upon Dynamo right now), so I use a lot of the Developers section of the Dynamo Forums.
    August 16, 2017
    1
    09:08 PM
    Further Q:
    Hello,
    Thank you for your scripts.
    I notice that the function only works when there is a corner. What I want is to turn off the "wall" join status using Dynamo, so that I can draw separated walls continuously following a line.
    Thanks,
    Kemp
    February 8, 2016
    2
    06:08 AM
    Hi amoursol,
    i have tried the scrip but i got the following warning:
    import clr
    walls = UnwrapElement(IN[0])
    success,failure = [],[]
    for wall in walls:
    try:
    TransactionManager.Instance.EnsureInTransaction(doc)
    WallUtils.DisallowWallJoinAtEnd(wall,0)
    WallUtils.DisallowWallJoinAtEnd(wall,1)
    TransactionManager.Instance.TransactionTaskDone()
    except:
    failure.append("Failure: Element category" +str
    OUT = (success,failure)
    November 21, 2012
    612
    05:08 AM
    Hello Mjkayali,
    Please go over my post higher up in the graph - indentation matters a lot in Python, so double check the code inside your node matches mine
  1. Replies: 0
    Last Post: November 14th, 2016, 10:17 PM
  2. "Join" two floor slabs of different materials, without the line where they join?
    By kescr in forum Architecture and General Revit Questions
    Last Post: September 15th, 2014, 01:17 AM
  3. "Element's internal join data is corrupt." - What's that all about?
    By Stuntmonkee in forum Architecture and General Revit Questions
    Last Post: January 12th, 2012, 07:56 PM
  4. beam/column join to create "rigid frame"
    By Scott Webb in forum Structure - General Questions
    Last Post: April 28th, 2011, 05:29 PM
