Results 1 to 2 of 2
Thread: titleblock parameters via dynamo
    July 19, 2017
    1
    02:50 AM
    I wonder if anyone could help, struggling to populate titleblock parameters via dynamo.
    1) Titileblock family which has Label family that carries parameters, those were populated in project via assigning new shared to sheets.
    2) When I try to get these parameters on Dynamo to be populated I cannot find a way of doing so. It seems that the reason is they are nested label parameters.
    Any Ideias?
    Attached Thumbnails Attached Thumbnails titleblock parameters via dynamo-help-image.jpg
    Junior Member PolynineStudio's Avatar
    April 25, 2017
    31
    09:50 PM
    Did you link the label family parameters to the titleblock family parameters?
    Make sure that you correctly added the shared parameter to your project, so that the label is linked properly.
    Let me know if this makes sense:
    "Sheet Instance Parameter" can be added as a project parameter (should be a shared parameter) to the Sheets category and then manipulated per sheet element. (Instance Parameter behavior)
    "Sheet Type Parameter" can be added as a project parameter (should be a shared parameter) to the Project Information category and then manipulated at project information / globally (Type Parameter behavior, affecting all sheets)
    If you are manipulating the project information data, you need to call out the correct element in dynamo.
  1. Titleblock -lost parameters
    By MARIA1993 in forum Architecture and General Revit Questions
    Last Post: February 16th, 2017, 06:41 PM
  2. How do I add additional instance parameters to a titleblock?
    By TuShay in forum Structure - General Questions
    Last Post: December 15th, 2016, 09:10 PM
  3. Replies: 0
    Last Post: July 31st, 2015, 05:15 AM
  4. Titleblock parameters - how to have multiple designers name in one place on titleblk?
    By cadmancan in forum Architecture and General Revit Questions
    Last Post: June 27th, 2013, 07:05 PM
  5. titleblock instance parameters for labels...help
    By spotless in forum Architecture and General Revit Questions
    Last Post: December 13th, 2011, 12:19 AM
