Page 1 of 2 12 LastLast
Results 1 to 10 of 14
Like Tree2Likes
Thread: Generate 3D views from Dynamo?
    Member ryntau's Avatar
    October 11, 2012
    St. Louis
    403
    08:28 PM
    Is it possible to create 3D views in Dynamo?
    My goal is to create a script that will generate a view for each workset in the project. I can create a list of worksets, but can't seem to generate the 3D view, unless i'm missing something obvious. Ideally, i'd like to isolate that 3D view to only show that workset, and hide the others, but i'm just focused on step one for now.
    October 11, 2012
    St. Louis
    403
    08:28 PM
    I may have figured out my own answer.. now, just need to figure out how to isolate a workset in its view.
    Attached Thumbnails Attached Thumbnails Generate 3D views from Dynamo?-worksets.png
    Gold Coast
    2,626
    01:28 PM
    Not at my comp right now but theres some go duscussions on dynamo forums about this
    Junior Member PolynineStudio's Avatar
    April 25, 2017
    31
    10:28 PM
    @ryntau
    Are you trying to permanently hide / isolate in the view or temporary?
    Here are some references:
    Topic: hide in view | Dynamo BIM
    https://www.revitforum.org/dynamo-bi...nt-dynamo.html
    You could also create the view from scratch. See image for reference.
    Attached Thumbnails Attached Thumbnails Generate 3D views from Dynamo?-revit_dyno.png
    October 11, 2012
    St. Louis
    403
    08:28 PM
    yes, permanently hide. One of the ways that I like to check if everything is on it's proper workset is to create a 3D view that only shows that workset, and hides everything else. Creating/Duplicating the view isn't that hard, but switching on the right workset has been dificult. Thanks for that tip.
    July 23, 2017
    1
    03:28 AM
    Trigonométrie
    Envoyé de mon SM-G930F en utilisant Tapatalk
    April 25, 2017
    31
    10:28 PM
    You want to control the vg setting for worksets (see image below)?
    If you grab all elements in the workset and then hide them, new elements will not respect the workset visibility, until you rerun your script.
    If you're comfortable workign in python, here's a good video that does this. If not, let me know, I can show you how to alter it for your purpose.
    https://www.youtube.com/watch?v=gQAWs4EheFk
    Attached Thumbnails Attached Thumbnails Generate 3D views from Dynamo?-revit_2017-07-23_09-47-01.png
    November 21, 2012
    London, United Kingdom
    612
    04:28 AM
    Hello Ryan,
    I've got half your graph sorted - just can't figure out how to also get System families... but maybe you'll have more luck. It's late here and I'm tired haha.
    Attached Files Attached Files
    April 25, 2017
    31
    10:28 PM
    @amoursol
    That's one way to approach the problem, especially if the script ties into a larger graph that needs access to the elements on that workset.
    @ryntau
    If the end goal is to have workset views that only show the elements on that specific workset, then I would use the visibility setting route. See image below and the attached dyn file for reference.
    The python script is an edited version of Drew Jarvis's (from Cansel) python script:
    https://knowledge.autodesk.com/suppo...AWs4EheFk.html
    Attached Thumbnails Attached Thumbnails Generate 3D views from Dynamo?-revit_2017-07-23_18-41-53.png   Generate 3D views from Dynamo?-capture.png
    amoursol likes this.
    April 25, 2017
    31
    10:28 PM
    Regarding duplicate views: it is better to create the views from scratch so that the user is not concerned with duplicate view selection. However, an annoying issue that comes up when you create the 3d axonometric views is that the view is locked by default. The altered script attached includes an extra python node that unlocks the 3d view.
    Attached Thumbnails Attached Thumbnails Generate 3D views from Dynamo?-revit_2017-07-23_19-01-42-unlock.png
  1. Unable to generate a Localfile
    By andreasdraxl in forum Architecture and General Revit Questions
    Last Post: April 4th, 2017, 09:18 AM
  2. Rotating multiple views using Dynamo
    By tpovey in forum Dynamo BIM
    Last Post: March 3rd, 2017, 12:48 PM
  3. Replies: 0
    Last Post: January 10th, 2014, 05:16 AM
  4. Replies: 0
    Last Post: September 23rd, 2013, 06:45 PM
  5. revision clouds in legend views do not generate revision schedule entries
    By hclbaumbach in forum Architecture and General Revit Questions
    Last Post: July 1st, 2013, 10:39 PM
