Results 1 to 7 of 7
Like Tree5Likes
  • 2 Post By DanielHurtubise
  • 3 Post By wwdreamb
Thread: Find and select the imported cad drawings in any given model?
    Member wwdreamb's Avatar
    May 19, 2016
    Honolulu, Hawaii
    119
    04:57 AM
    Hey all,
    I am trying to find and select the imported cad drawings in any given model. How do I get it to specify or navigate/highlight (make it easy to locate) to a selected imported dwg?
    see image 1 for what I did. See image 2 showing two CAD drawings 1 Linked and the other Imported.
    Revit 2016
    Dynamo 3.1
    Attached Thumbnails Attached Thumbnails Find and select the imported cad drawings in any given model?-temp1.png   Find and select the imported cad drawings in any given model?-temp2.png
    February 2, 2011
    Montreal/Paris
    830
    06:57 AM
    Use Documents.LinksAndImports from the Clockwork package
    amoursol and PolynineStudio like this.
    May 19, 2016
    Honolulu, Hawaii
    119
    04:57 AM
    Quote Originally Posted by DanielHurtubise View Post
    Would I use that instead of the Element Types?
    May 19, 2016
    Honolulu, Hawaii
    119
    04:57 AM
    Quote Originally Posted by wwdreamb View Post
    OK this is what I came up with and it works! After I see the list of Imported documents, I can attach the Erase tool and run it again and BOOM they gone!
    Attached Thumbnails Attached Thumbnails Find and select the imported cad drawings in any given model?-temp3.png
    cellophane, amoursol and cridenour like this.
    February 3, 2012
    3
    04:57 AM
    Selectively erase?
    Will this allow me to SELECTIVELY erase certain cad imports?
    Member Bjorn_K's Avatar
    April 8, 2011
    Rotterdam, Netherlands
    316
    01:57 PM
    Based on what SELECTION criteria?
    February 2, 2011
    Montreal/Paris
    830
    06:57 AM
    Use a Data-Shapes dialog box to have the user select the import instances to remove
  1. Imported Categories Named "1" - Cannot purge/delete/find in groups...
    By Jj Mac in forum Architecture and General Revit Questions
    Last Post: April 25th, 2018, 01:29 PM
  2. Easy way to find dozens of imported CAD files?
    By TRWhitehead in forum Architecture and General Revit Questions
    Last Post: October 6th, 2017, 01:51 PM
  3. Find, select, and review any element in your Revit model with Ideate QuickSelect
    By Rwtaylor_Revit in forum Third party Add-Ins, API and R&D
    Last Post: February 21st, 2017, 09:53 PM
  4. How to Find / Select Imported DWG in Revit using DynamoBIM
    By Simply Complex in forum Blog Feeds
    Last Post: May 21st, 2015, 05:45 AM
