Page 1 of 2 12 LastLast
Results 1 to 10 of 13
Like Tree8Likes
Thread: Element.GetParameterValueByName Use
    June 6, 2017
    4
    10:07 AM
    I'm trying to get the height of walls by Element.GetParameterValueByName
    But it doesn't work
    I tried the same way used for windows (it worked for windows but not walls)
    Photos are in Attachements
    Attached Thumbnails Attached Thumbnails Element.GetParameterValueByName Use-fonctionne-mais-donne-valeures-nulles.png   Element.GetParameterValueByName Use-essai-avec-family-instance-get-type.png   Element.GetParameterValueByName Use-fonctionnelle-pour-fen%EAtres.png
    November 21, 2012
    London, United Kingdom
    612
    11:07 AM
    Hello Anasanas,
    I'm not sure what it will be in another language beyond English, but in the English version we use Unconnected Height to give us the height of a wall.
    As showcased below:
    Attached Thumbnails Attached Thumbnails Element.GetParameterValueByName Use-revitforumquery_wallheight.jpg
    June 6, 2017
    4
    10:07 AM
    I still have the problem maybe i have to load another version of Dynamo than 1.3?
    Quote Originally Posted by amoursol View Post
    Hello Anasanas,
    As showcased below:
    Problem still exists, For info I can use the parameters in english without problem. Thank you
    Attached Thumbnails Attached Thumbnails Element.GetParameterValueByName Use-capture.png
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,104
    06:07 AM
    You need to capitalize the parameter name: Unconnected Height, not Unconnected height.
    amoursol likes this.
    June 6, 2017
    4
    10:07 AM
    The problem is still here, do you think I have to load another version of Dynamo than 1.3? I take the same program as amoursol and it gives me a null list
    November 21, 2012
    612
    11:07 AM
    As Cellophane mentioned, when you type in Dynamo is is very case sensitive. As per your image, you need to use a capital letter for the word Height. Please fix that first and see if it works.
    June 6, 2017
    4
    10:07 AM
    it did not actually. it is weird
    Attached Thumbnails Attached Thumbnails Element.GetParameterValueByName Use-suppp1.png   Element.GetParameterValueByName Use-suppp2.png   Element.GetParameterValueByName Use-supp3.png
    jmk
    jmk is offline
    Forum Addict jmk's Avatar
    December 31, 2012
    NM, USA
    1,415
    04:07 AM
    If you use element.parameters does the value you wish to pull show in the list?
    July 7, 2011
    Rotterdam, Holland
    1,169
    12:07 PM
    It looks like you are using a French Revit, so I guess that you need to use "Hauteur non contrainte" for your parameter name instead of just "hauteur" or Unconnected Height. You need to use the exact text that shows up in your properties window, language and the capitals included.
    amoursol and boucher57 like this.
    June 20, 2017
    9
    10:07 AM
    I agree with Robin and...
    i'm french user!
    But let me suggest you to start writing your code in english...
    Sent from my SM-N910W8 using Tapatalk
  1. Copy Rebar from element to element
    By Nsync in forum Structure - General Questions
    Last Post: March 31st, 2017, 02:21 PM
  2. Replies: 1
    Last Post: January 16th, 2016, 05:49 PM
  3. Switching element type to Curtain element.
    By MPwuzhere in forum Architecture and General Revit Questions
    Last Post: February 27th, 2015, 11:07 PM
  4. Replies: 0
    Last Post: February 12th, 2015, 02:15 AM
  5. element Id and element Type Id
    By Patrick in forum Third party Add-Ins, API and R&D
    Last Post: July 6th, 2012, 10:50 PM
