Results 1 to 3 of 3
Thread: Linking Dynamo To Revit - Import Instance by Geometry Not Working
    Junior Member KumarKapadia's Avatar
    February 25, 2016
    33
    08:16 AM
    Hello Everyone,
    Hereby m running into some silly issues and want u pple to help me solve it..
    DESIGN IS READY, SCRIPT IS READY, IMPORTINSTANCE BY GEOMETRY not working.
    i have a generic model in revit as elevation treatment of a building facade which i want to edit in dynamo and so did i scripted it out and its perfectly responding is dynamo when i linked the revit file to dynamo but the moment i connect the SOLID DIFFERENCE BY ALL node to IMPORT GEOMETRY BY INSTANCE node as u see in file the wheel keeps steering for hours and nothing really happens ......plz help me out resolve my issue and revert back asap.
    Hereby M attaching both - Revit File & Dynamo Script
    Thanks In Advance
    Regards,
    Kumar
    Attached Thumbnails Attached Thumbnails Linking Dynamo To Revit - Import Instance by Geometry Not Working-working.jpg   Linking Dynamo To Revit - Import Instance by Geometry Not Working-error.jpg
    Attached Files Attached Files
    February 25, 2016
    33
    08:16 AM
    No reply ?
    May 30, 2015
    201
    09:46 PM
    You might try exporting to sat to test what the geometry is and if it is accurate
  1. CAD geometry is currupt when importing or linking
    By danezeq in forum Architecture and General Revit Questions
    Last Post: August 2nd, 2016, 10:56 AM
  2. dynamo geometry to revit - not responding
    By kunster in forum Dynamo BIM
    Last Post: January 29th, 2016, 09:26 PM
  3. How to Import Line Weights from AutoCAD when Linking drawings into Revit
    By j2mattones in forum Architecture and General Revit Questions
    Last Post: November 19th, 2014, 03:18 AM
  4. Replies: 0
    Last Post: April 27th, 2013, 01:16 PM
