Results 1 to 4 of 4
Like Tree3Likes
  • 3 Post By amoursol
Thread: Thoughts on node/graph cleanup
    Member ryntau's Avatar
    October 11, 2012
    St. Louis
    401
    09:29 AM
    I'm working on a dynamo graph that utilizes the same dozen data points in different ways and I found myself getting annoyed with all of the wires going everywhere. I ended up created a code block that passes all of the data through it, much like a zip tie holding together a bunch of cables going to the same place. Each of the purple blocks on attached image are exactly the same, so there is some duplication, but i find it helps because i don't have to pan as far to wire the data. I was wondering if anyone does something similar or if there are other methods you have cleaning up and make things look organized.
    I've attached two images, one was in process of cleaning, and the other is the finished result.
    Attached Thumbnails Attached Thumbnails Thoughts on node/graph cleanup-cleanup.png   Thoughts on node/graph cleanup-cleanup02.png
    jmk
    jmk is online now
    Forum Addict jmk's Avatar
    December 31, 2012
    NM, USA
    1,415
    10:29 AM
    I've used something similar several times, to collate info going through nodes, or as a repeater to prevent leads going through other nodes (especially when something from my user input node isn't needed until late in the script)
    March 21, 2013
    Phoenix, AZ
    275
    09:29 AM
    I use this method very frequently now. I was using the inputs of custom nodes for that purpose, but quickly found that there's no viable way to debug in the custom node editor.
    November 21, 2012
    London, United Kingdom
    612
    05:29 PM
    In all honesty, if there is even a semblance of re-use (Or even not), it's often really good to package up together a set of nodes into an in-house package. That way, if it's doing a whole bunch of calculations it's zipped up in a way. It cleans up the graph a lot.
    Alternatively, you can use code blocks or wrap functions into python.
    My general rule of thumb (increasingly) is that if there is a single input and a single output to a whole bunch of stuff - wrap it up!
  1. Replies: 7
    Last Post: January 13th, 2017, 12:41 PM
  2. My Very First Dynamo Graph (no laughing...)
    By Twiceroadsfool in forum Dynamo BIM
    Last Post: January 11th, 2017, 02:06 PM
  3. Replies: 0
    Last Post: June 24th, 2016, 01:45 AM
  4. Autodesk University: Develop3D talks Design Graph
    By Autodesk University in forum Blog Feeds
    Last Post: January 21st, 2016, 07:45 PM
  5. Is it possible to create a doughnut graph?
    By barry.farmer in forum Architecture - Family Creation
    Last Post: January 6th, 2016, 07:38 PM
