Results 1 to 5 of 5
Like Tree5Likes
  • 1 Post By ryntau
  • 3 Post By Bjorn_K
  • 1 Post By amoursol
Thread: Placing a Door into a wall with Dynamo?
    Member ryntau's Avatar
    October 11, 2012
    St. Louis
    403
    08:05 PM
    I'm creating a dynamo script where you input the Length and Width of the simple building and it draws your grids, and tiltup walls based on the parameters you put in, this part works great. The walls are drawn by using Point.ByCoordinates for the start and end points, then a Line.ByStartPointEndPoint is created connecting the two, and finally a wall is generated using Wall.ByCurveAndHeight.
    I'd like to host a door in each wall panel, but for some reason, any attempt i do to place the family instance fails..
    Does anyone have any guidance on placing a door/window family in a wall?
    I've tried using to learn from this dynamo script:
    Topic: How to put a door or window object on the wall ? | Dynamo BIM
    but all it does is run through the task, return no errors, but not actually place any objects.
    Mengelmn likes this.
    Member Bjorn_K's Avatar
    April 8, 2011
    Rotterdam, Netherlands
    319
    05:05 AM
    Need a bit more info to give advice why it's not working.
    Here's a quick sketch how it can work:
    Attached Files Attached Files
    amoursol, ryntau and Andres Franco like this.
    October 11, 2012
    St. Louis
    403
    08:05 PM
    Thank you! that was immensely helpful.
    October 11, 2012
    St. Louis
    403
    08:05 PM
    alright, I might need one more tip, i swapped out the walls in your graph, for walls generated by points and hit a stumbling block. both the Wall and the curve are created, but nothing is passing into the spring nodes. any suggestions?
    Attached Thumbnails Attached Thumbnails Placing a Door into a wall with Dynamo?-doorinwall.png
    November 21, 2012
    London, United Kingdom
    612
    04:05 AM
    Ryan, I believe it's because you have the 'same distance' between nodes, so in essence Dynamo is trying to run a couple simultaneously.
    Try adding in a passthrough node (Clockwork package) before your Spring Node. If you can't figure it out - just holla.
    Andres Franco likes this.
  1. Can't make type error when placing door
    By NathanCalvert in forum Architecture and General Revit Questions
    Last Post: September 1st, 2015, 09:41 PM
  2. Placing Door on In-Place Massing Wall with Voids
    By cathode43 in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: November 22nd, 2014, 06:59 PM
  3. Placing headers in radial wall
    By caseym in forum Structure - General Questions
    Last Post: February 15th, 2014, 06:51 PM
  4. Buildz: Dynamo: Placing Adaptive Components
    By Buildz in forum Blog Feeds
    Last Post: June 11th, 2013, 01:15 PM
  5. Placing family to the top of wall!?
    By Parametric Snowman in forum Architecture - Family Creation
    Last Post: June 14th, 2012, 06:59 PM
