Results 1 to 1 of 1
Thread: Need help debugging a script
    June 13, 2014
    Milwaukee
    232
    05:53 AM
    Hello all,
    I have a functioning script for placing fire rating detail components on my walls, the issue I have is that it appears that the script works for all levels but in revit it only shows the detail components on all levels except Level 1.
    Is there someone who is willing to take a look and see why.
    The Revit File is located here:
    https://drive.google.com/open?id=0Bw...lJDRDZWY2FnbnM
    I attached the script and a custom node that I use.
    Thanks in advance. This is also posted on the dynamo forum.
    https://forum.dynamobim.com/t/need-h...cript/10743/50
    Attached Files Attached Files
  1. Replies: 0
    Last Post: September 4th, 2014, 09:15 AM
  2. Replies: 0
    Last Post: May 28th, 2013, 09:15 AM
  3. Building Coder: Revit 2014 SDK and Visual Debugging Tools
    Last Post: May 2nd, 2013, 10:45 AM
  4. Replies: 0
    Last Post: October 31st, 2012, 10:15 AM
  5. debugging build error
    By Alex Cunningham in forum Third party Add-Ins, API and R&D
    Last Post: June 13th, 2011, 11:41 PM
