Results 1 to 5 of 5
Like Tree1Likes
  • 1 Post By GMcDowellJr
Thread: Dynamo overwrites revit elements
    April 19, 2017
    1
    03:14 PM
    I'm working with Dynamo 1.2.1 with rebars. Each time I re-run my script on different elements it overwrites elements generated in the previous step even if I save and close both Dynamo and Revit.
    I create bars and they appear in Revit but, when I change input of the script and re-run it, it generates new elements but the previous ones disappear.
    Could somebody help me?
    jmk
    jmk is offline
    Forum Addict jmk's Avatar
    December 31, 2012
    NM, USA
    1,415
    07:14 AM
    It will probably take people familiar with rebar, but posting your current script will help.
    Gold Coast
    2,602
    11:14 PM
    I dont use rebar but i learnt that lesson the hard way when dynamo randomly overwrote a big stack of my sheets and losing all the placed views, even though all new sheet numbers were unique. Also i couldnt undo bc of 'non editiable' workset ownership warning - so also sync and get ownership of worksets before running dynamo What i do currently is set my script to create sheets using a different type of titleblock (one not in use), then select all and change the family type over, this process doesnt overwrite existing.
    Im sure there's a way in dynamo to filter existing ID's or something & not just overwrite stuff but im not that clever yet.
    Member HansLammerts's Avatar
    April 22, 2011
    441
    01:14 PM
    Quote Originally Posted by ObBis View Post
    Just .. Wow! (however, this sound familiar as many other dumbass macro in any other cad (bims) software would do this. It helps you wanting making any sheey. I would advice you to Ask Autodesk to come back later.
    December 21, 2010
    Phoenix, AZ
    2,556
    06:14 AM
    This is just how Dynamo works. It doesn't commit changes until it's either told to commit the change via a "transaction" or exiting the graph. If it didn't work this way you'd have a heck of a time building the graph! There are lots of threads on this over at the Dynamo forums including methods to commit changes.
    amoursol likes this.
  1. Replies: 0
    Last Post: August 15th, 2016, 12:15 PM
  2. Replies: 1
    Last Post: January 16th, 2016, 05:48 PM
  3. Revit 2015 to Revit 2016 Structural Column Overwrites incorrect sizes
    By bails1974 in forum Architecture and General Revit Questions
    Last Post: November 20th, 2015, 10:33 AM
  4. Replies: 0
    Last Post: November 19th, 2014, 12:45 PM
  5. Replies: 0
    Last Post: August 26th, 2013, 07:45 AM
