Page 1 of 2 12 LastLast
Results 1 to 10 of 19
Like Tree4Likes
Thread: Read only Parameter error from Element.SetParameterByName node?
    "I am NOT a Revit tutor!"
    Dave Jones's Avatar
    4,509
    12:15 AM
    see this. Why would the built in Revit Sheet Number parameter throw a read only error?
    December 21, 2010
    Phoenix, AZ
    2,628
    12:15 AM
    What element are you feeding the node?
    Dave Jones's Avatar
    4,509
    12:15 AM
    A sheet list
    December 21, 2010
    Phoenix, AZ
    2,628
    12:15 AM
    At least in earlier versions of Dynamo, not all parameters could be obtained this way. You has to use Built-In parameters. Still, I'd surprised this was one that needed it. There aren't non-editable sheets in the list, like from a linked model, by chance?
    Dave Jones's Avatar
    4,509
    12:15 AM
    Quote Originally Posted by GMcDowellJr View Post
    nope, in project sheets using the OOTB Revit Sheet Number instance parameter. Add Sheet Numbers.dyn is attached. The idea is to connect the String.Insert wire in the Add Temp Suffix group to the Element.SetParameterByName node to add a "z" suffix to all sheets including the sheets being added to get around the Revit duplicated sheet error. Then connect the wire from the String.Insert wire from the Add Sheet Prefix group to the Element.SetParameterByName node to delete the suffix. The initial wire connection brings the error on Run
    btw, credit for this graph to Michael KilKelly at ArchSmarter in a YouTube tut
    Attached Files Attached Files
    November 21, 2012
    London, United Kingdom
    612
    08:15 AM
    There is a known bug that is looking at getting addresses in a future release of Dynamo. Basically, there is a conflict issue between named parameters and 'nicknamed' parameters.
    The best work-around at present is to use the Built-In Parameters in lieu of the nicknames.
    Dave Jones's Avatar
    4,509
    12:15 AM
    Quote Originally Posted by amoursol View Post
    isn't the instance parameter "Sheet Number" an OOTB built in parameter? The project that I'm running this graph on has no project parameters so in theory only built in parameters would be available. Unless I'm unclear on the concept which could certainly be the case as I'm only a few days into the Dynamo learning process.
    I'm attaching a small project file with the sheets created. I have sheets A100 thru A180 and A200 thru A205. I'm trying to add 5 sheets into the list in the A100 series and they are included in the sheet list with an "A" suffix to get them in the correct order where I would like them added.
    I am using Dynamo 1.2.1 in Revit 2015
    Edit: just for grins I installed Dynamo 1.3 and ran the graph in R2017.2 and it works perfectly. Some issue with either Dynamo 1.2.1 or R2015 or both
    November 21, 2012
    612
    08:15 AM
    I tried to find the Github link but failed... not my day I guess
    Effectively, there is multiple parameters in Revit called the same thing. So it get's confused and tries to set the 'Read Only' data rather than the other. It's because the Revit API is 'fun'. It's definitely random in it's uptake - and generally you don't see the issue.
    December 21, 2010
    Phoenix, AZ
    2,628
    12:15 AM
    Yes, in 1.3 they improved the handling of parameter names. What used to require a BUILT-IN can now be done with the "nicknamed" versions.
    amoursol likes this.
    Dave Jones's Avatar
    4,509
    12:15 AM
    thanks amoursol! lots to learn about the idiosyncracys of Dynamo
    well, that sorta sucks since I have 3 projects going in R2105. Oh well, the graph will be useful in the future. Thanks Greg!
  1. Trying to get an elevation tag to read a parameter
    By joewallace in forum Architecture and General Revit Questions
    Last Post: March 16th, 2017, 09:11 PM
  2. Node to read totals from schedules.
    By Revitaoist in forum Dynamo BIM
    Last Post: November 20th, 2015, 06:45 AM
  3. How to read/edit lighting fixture parameter
    By kukuzry in forum Third party Add-Ins, API and R&D
    Last Post: January 23rd, 2014, 02:39 AM
  4. Building Coder: Read Material Asset Parameter
    Last Post: January 30th, 2013, 09:15 AM
  5. Door tag to read parameter
    By Alfienoakes in forum Architecture and General Revit Questions
    Last Post: July 14th, 2011, 09:08 PM
