Results 1 to 8 of 8
Like Tree6Likes
  • 3 Post By josephpeel
  • 1 Post By amoursol
  • 1 Post By cellophane
  • 1 Post By josephpeel
Thread: Sheet Renumbering
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,140
    11:31 PM
    Sheet Renumbering
    Dumb question on renumbering sheets: Usually when I need to renumber sheets it is because I have to add a sheet which throws off my sequencing. I can export sheets and renumber in excel with no problems but I hit an issue when I bring things back into Revit since the sheet numbers technically already exist. Is there a way around this that I'm just missing other than swapping letters around - i.e. A101 to B101 to A102?
    10,179
    10:31 PM
    Depends how you are doing the renumbering from excel: you have to use a tool that let's you specify the processing order, and can work from the top down. I don't recall if yoy can do that with Spreadsheet a link or not. But I imagine you can if you resort the lists a certain way?
    May 3, 2012
    1,401
    05:31 AM
    You could do it with excel if you add an extra step. First import/change all your sheet numbers to something else (Like add a letter to the end of the existing numbers, still unique), then import the actual numbers you want.
    Personally I made a simple 'Find and replace' tool in dynamo for both sheet and view names. Extremely useful when you want to adjust part of the name for all sheets.
    amoursol, cellophane and cganiere like this.
    November 21, 2012
    London, United Kingdom
    612
    04:31 AM
    Joseph's right, you simply need to add into your script an interim step that renames them to something arbitrary first.
    Exiting Names -> Arbitrary (So no conflict) -> New names (Utilising some existing names).
    You can use the Clockwork node Passthrough to make sure that your Dynamo sequencing executes in the correct order.
    cellophane likes this.
    August 9, 2011
    Louisville, KY
    6,140
    11:31 PM
    Thanks!
    Quote Originally Posted by josephpeel View Post
    Is that something you can share? I'm good with just a screenshot - helps me figure things out on my end if I actually have to build it
    Quote Originally Posted by amoursol View Post
    I'll take a look at it and see what I can muddle together.
    amoursol likes this.
    May 3, 2012
    1,401
    05:31 AM
    Something like this
    cganiere likes this.
    August 9, 2011
    Louisville, KY
    6,140
    11:31 PM
    Cool! One quick question: Is the Change View Name node a boolean that you renamed?
    May 3, 2012
    1,401
    05:31 AM
    yep. I just gave then names to show what they do.
    Probably better to rename them "Boolean - do stuff" to avoid confusion.
  1. Room Renumbering Effect on MEP
    By Juniper01 in forum MEP - General
    Last Post: April 1st, 2016, 08:55 PM
  2. Renumbering views on sheets
    By Juniper01 in forum Architecture and General Revit Questions
    Last Post: October 22nd, 2015, 03:09 PM
  3. Revisions and renumbering (2014)
    By Jrobker in forum MEP - General
    Last Post: March 31st, 2015, 05:57 PM
  4. Renumbering Objects with the same mark - macro?
    By cellophane in forum Third party Add-Ins, API and R&D
    Last Post: January 27th, 2013, 05:53 PM
  5. Replies: 0
    Last Post: June 25th, 2012, 06:45 AM
