Results 1 to 4 of 4
Like Tree2Likes
  • 2 Post By amoursol
Thread: Copying Parameters
    March 13, 2012
    59
    03:50 AM
    Copying Parameters
    In the neverending quest to help automate some boring stuff, I'm hoping to make a dynamo script to do the following:
    - take the system parameter of "Area" of certain Detail Item Filled Regions (which exists, but cannot be scheduled)
    - copy the parameter into my own "Filled Region - Area" parameter
    The reason is that I'd like to automate the calculation of Exposing Building Face calculations - wherein you tabulate the area of a facade next to a property line, tabulate the area of the unprotected openings, and report the latter as a percentage of the former. It's easy enough to give the filled region a name or parameter so that my schedule is sorted according to building facade and area type (see attached image), but I currently have to copy the areas by hand. Imaginit has a "Parameter Copy" tool as part of one of their suites, but with Dynamo being integrated into Revit now I'm hoping to save the cost of getting such a tool for a 20+ person firm.
    Anyone have any tips on how I could do something like this with Dynamo?
    Attached Thumbnails Attached Thumbnails Copying Parameters-filledregion_property.png
    November 21, 2012
    London, United Kingdom
    612
    08:50 AM
    Hello Guitarchitect,
    This should be what you're after
    You don't actually have to filter the Filled Regions versus the Masking Regions as the project parameter will apply to both and there is no harm done. I just included this as a further example of filtration.
    Attached Thumbnails Attached Thumbnails Copying Parameters-revitforumquery_areas.png
    cganiere and PolynineStudio like this.
    April 27, 2011
    Paw Paw, Michigan, United States
    44
    03:50 AM
    Sorry to infiltrate this thread but is this a way for you to accomplish a Com Check?
    November 21, 2012
    612
    08:50 AM
    Quote Originally Posted by jmqrsq View Post
    Short answer: Yes.
    Long answer: How do you specifically want to achieve it?
  1. copying from one project to another
    By fifthtexas in forum MEP - General
    Last Post: November 4th, 2014, 07:57 AM
  2. Copying Elements
    By cwwalder in forum MEP - General
    Last Post: February 26th, 2014, 01:23 PM
  3. Views & Copying
    By nick_h in forum MEP - General
    Last Post: January 15th, 2014, 12:58 PM
  4. Trouble Copying
    By Aaralyn in forum Architecture and General Revit Questions
    Last Post: January 3rd, 2013, 01:07 PM
  5. Replies: 0
    Last Post: March 15th, 2012, 11:15 PM
