Results 1 to 5 of 5
Thread: Using Excel to drive HP pier foundation heights
    Member ryntau's Avatar
    October 11, 2012
    St. Louis
    403
    06:08 AM
    I feel like i'm missing something really easy here. I'm trying to use an excel table to drive my elevation heights. I currently have all of the piers placed in the right spot with Marks. but for some reason the Elements.SetParameterByName is not setting my elevation offset. Any help would be much appreciated?
    Attached Thumbnails Attached Thumbnails Using Excel to drive HP pier foundation heights-sfpier_elevation.png
    Attached Files Attached Files
    May 30, 2015
    203
    08:08 AM
    Quote Originally Posted by ryntau View Post
    The Element input expects a list of "revit elements" currently you are inputting "values"
    October 11, 2012
    St. Louis
    403
    06:08 AM
    That makes sense. I'm not sure how to input the elements in the correct order (by Mark) ?
    May 30, 2015
    203
    08:08 AM
    Try looking at 'sort by key' this should allow you to sort the original element list by the Mark value list.
    November 21, 2012
    London, United Kingdom
    612
    02:08 PM
    Hello Ryntau,
    Is this what you are after?
    Bear in mind that this system works on internal logiac, so that it functions correctly with regards to numbers but will fail if we have a different mark system.
    For example:
    W1
    W11
    W12
    W13
    W2
    W21
    In lieu of an actual ordering system. In this case, you would have to split the string into numbers only for ordering purposes.
    Attached Thumbnails Attached Thumbnails Using Excel to drive HP pier foundation heights-revitforumquery_ryntau_sorting.jpg
  1. Renaming From Excel - After Sorting Data in Excel
    By cellophane in forum Dynamo BIM
    Last Post: January 18th, 2016, 01:24 PM
  2. Replies: 0
    Last Post: October 19th, 2015, 05:15 AM
  3. Replies: 3
    Last Post: June 6th, 2015, 11:18 AM
  4. create Foundation Tag to be placed at foundation corner
    By khalid_omar in forum Structure - Family Creation
    Last Post: March 30th, 2015, 10:16 AM
  5. SSD as os drive or data drive
    By Zacsixchip in forum Hardware and Infrastructure
    Last Post: April 12th, 2013, 06:19 PM
