Results 1 to 5 of 5
Like Tree11Likes
  • 5 Post By DaveP
  • 1 Post By snowyweston
  • 2 Post By josephpeel
  • 2 Post By DaveP
Thread: Ceiling Height filters
    Moderator DaveP's Avatar
    January 10, 2011
    St Paul, MN
    3,010
    02:40 AM
    Thought I'd share.
    A post on Phillip Chan's blog reminded me of this graph I've written recently to create Filters based on every Ceiling Height in a project.
    It's relatively customized to our office standards, but shouldn't be too hard to modify.
    The graph find all Ceiling Heights in a project and creates a Filter for each height, named RCP-height
    Then it applies all of those Filters to a View Template named Coordination - RCP Ceiling Heights using our company standard color palette
    It's still got a few rough edges - I'm using the SpringNodes Feet2Fraction and that occasionally converts 8'-8" to 8'-7 2/2"
    I also kind of hard-wired the node that creates the Filter to do only Ceiling Heights - that need to be more generic.
    Feel free to use, modify improve and/or criticize.
    Attached Files Attached Files
    Last edited by DaveP; March 10th, 2017 at 03:34 PM. Reason: Had to ZIP the two .dyf files - those aren't uploadable to RFO
    December 21, 2010
    C.LONDON
    4,392
    08:40 AM
    Having an Enscape evening but will be checking this out Monday.
    Thomas Schander likes this.
    May 3, 2012
    1,403
    09:40 AM
    Ive used filters for ceiling height before, but abandoned it because you first need to know what they are before making all the filters and it doesnt update with changes. Doing it programatically solves that issue I guess.
    This solution is also very intersting;
    https://forum.dynamobim.com/t/genera...heights/7604/7 (Bottom of the thread)
    Using the Analysis Display could be a good option because you can potential project it over any view without changes to the filter and template.
    amoursol and cellophane like this.
    December 21, 2010
    C.LONDON
    4,392
    08:40 AM
    Quote Originally Posted by josephpeel View Post
    If you can get it to work, my efforts failed, and I resorted to populating "Unbounded Height" into a new SP which we can now use Colour Schemes on.
    josephpeel likes this.
    January 10, 2011
    St Paul, MN
    3,010
    02:40 AM
    Here's a new version.
    A few bugs fixed, the whole routine is now more generic and thus (hopefully) more adaptable to other parameters.
    I also wrote my own "FeetInchesFraction" node to replace the SpringNodes Feet2Fraction, which had a tendency to return 8" as 7 2/2"
    (and thanks to Gordon for now allowing .dyf files to be uploaded)
    Last edited by DaveP; March 20th, 2017 at 09:15 PM. Reason: Updated FeetInchesFraction after an hour
    amoursol and josephpeel like this.
  1. Room Objects Not recognizing ceiling for automatic room height
    By sdbrownaia in forum Architecture and General Revit Questions
    Last Post: May 18th, 2016, 03:21 PM
  2. How to set the wall height to respond to ceiling heights instead of levels?
    By fleentrain89 in forum Architecture and General Revit Questions
    Last Post: April 28th, 2016, 07:42 PM
  3. floor height tag in reflected ceiling plan (2015)
    By ledgewood33 in forum Architecture and General Revit Questions
    Last Post: September 24th, 2015, 12:08 PM
  4. Calculated Value (Ceiling Height) in Room Tag?
    By blusurfer in forum Architecture - Family Creation
    Last Post: September 11th, 2015, 03:23 AM
  5. pier height anchor bolt height problem
    By Darius in forum Structure - Family Creation
    Last Post: November 20th, 2014, 08:26 PM
