Results 1 to 2 of 2
Like Tree2Likes
  • 2 Post By tpovey
Thread: Rotating multiple views using Dynamo
    October 14, 2014
    2
    09:47 PM
    Hi Everyone,
    First time poster here!
    I'm pretty new at using dynamo, i've made a few scripts but nothing overly complicated. The script below has been made by doing a bit of research and manipulating previously created scripts.
    I have made a dynamo script which creates bounding boxes around Revit geometry, which then creates multiple sections views at each bounding box. The issue is the section is facing the wrong way, so I'm in the middle of another script to try and flip the section, but it seems to be flipping about the wrong origin. I have read here that sections have their own coordinate system but i haven't managed to get it to work. Below is the script and the section facing the wrong way:
    Any help is appreciated!
    Attached Thumbnails Attached Thumbnails Rotating multiple views using Dynamo-section-flip.png
    October 14, 2014
    2
    09:47 PM
    Managed to fix it using Dieter's tutorial through this linkand Dimitar's suggestions from this link. Used Vector.Rotate to get the correct orientation.
    amoursol and Ning Zhou like this.
  1. convert Revit multiple 3D views to Navisworks views
    By Ning Zhou in forum Coordination Tools
    Last Post: April 19th, 2014, 03:50 AM
  2. Rotating Views
    By Jamma79 in forum Architecture and General Revit Questions
    Last Post: December 11th, 2013, 05:08 PM
  3. Rotating views
    By edmund in forum Structure - General Questions
    Last Post: January 16th, 2013, 11:53 AM
  4. Rotating views at angles different then 90deg.
    By lucis29 in forum Architecture and General Revit Questions
    Last Post: September 10th, 2012, 03:55 PM
  5. Rotating Views
    By Jack in forum Architecture and General Revit Questions
    Last Post: August 29th, 2012, 03:05 AM
Tags for this Thread
