Page 1 of 2 12 LastLast
Results 1 to 10 of 18
Like Tree2Likes
Thread: Placing adaptive components
    Member Andrew P's Avatar
    February 19, 2011
    362
    09:19 PM
    I"m trying to place 22 point adaptive components on a curved element. I'm having trouble grouping the 22 points, using either the sublist or the getittematindex node. I've tried doing the same setup with a simple rectangular face where i tried to place a 4 point adaptive component on a surface without using the lunchbox node since at the end I would need to group them anyhow. How do I get to group any amount of nodes in order to place an adaptive component on them?
    Attachment 29445
    Attached Thumbnails Attached Thumbnails Placing adaptive components-adaptive-component.jpg
    Attached Files Attached Files
    July 20, 2011
    850
    02:19 PM
    if I understand correctly, perhaps you can use list.chop w/ 4 lengths after flatten lists into single list w/ correct (AC placement) order, this will put 5 4-point ACs, you may have to use 2-point AC to add last one
    February 19, 2011
    362
    09:19 PM
    Actually this i what i'm trying to in Dynamo. I have an adaptive component family consisting of 22 points.
    At this moment i've placed that family manually in a massing family.
    And I've used the repeater to array the families.
    I'm trying to automate this process in Dynamo by grouping 22 points, but can't get it to work. Hopefully this explains what i'm trying to do.
    July 20, 2011
    850
    02:19 PM
    22 points AC instead of 4 points? man!
    November 21, 2012
    London, United Kingdom
    612
    10:19 PM
    Is there a reason you cannot achieve this with a 4pt node?
    February 19, 2011
    362
    09:19 PM
    Quote Originally Posted by amoursol View Post
    It needs to be a smooth curve and not segmented.
    Gold Coast
    2,617
    07:19 AM
    Quote Originally Posted by Andrew P View Post
    Although you'll still see edges when views are set to show them, you can get perfetly smooth panels using 9 points. Not as few as 4, but way less than 22.
    https://youtu.be/POND315utnY
    November 21, 2012
    612
    10:19 PM
    I had a quick look at re-creating this issue this morning but ran into and Adaptive Point issue. Could you please provide a screenshot of your Adaptive Family showcasing how you have distributed your points?
    February 19, 2011
    362
    09:19 PM
    But more importantly, how did you grouped the points whether it's 4, 6 or 22 points? Did you use sublist node?
    July 20, 2011
    850
    02:19 PM
    flatten lists into single list w/ correct (AC placement) order, and use List.Chop w/ 22 lengths.
    using sublist seems more complex.
  1. New to adaptive components
    By dtp81390 in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: February 3rd, 2016, 10:26 AM
  2. Buildz: Dynamo: Placing Adaptive Components
    By Buildz in forum Blog Feeds
    Last Post: June 11th, 2013, 01:15 PM
  3. Placing components problems
    By paddy in forum Architecture and General Revit Questions
    Last Post: March 1st, 2013, 04:50 PM
  4. Joining Adaptive Components
    By mfrietze in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: July 20th, 2012, 07:10 AM
  5. Problem when placing adaptive component
    By pjetrus in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: May 2nd, 2012, 10:37 AM
