Results 1 to 6 of 6
Like Tree2Likes
  • 1 Post By DanielHurtubise
  • 1 Post By tuekappel
Thread: Dynamo Trouble
    December 1, 2011
    Hong Kong
    39
    06:30 PM
    Dynamo Trouble
    I'm having trouble getting started with Dynamo. When I open the player in Revit, the window is empty, see image. Even when I try to open packages, it simply does not load it. This happens on all the Revit workstations on our office network.
    Btw, we are running Revit 2017 on Windows 10. We have uninstalled Dynamo, deleted all files and folders and registery entries for Dynamo, then reinstalled it, but still the same.
    Has anyone had this problem? I would really appreciate some help.
    10,036
    05:30 AM
    Player isn't for opening Packages. It's for listing graphs in a particular directory, so you can run them. There is nothing wrong with your system. Youre trying to use it incorrectly.
    Sent from my T1-A22L using Tapatalk
    December 1, 2011
    Hong Kong
    39
    06:30 PM
    Yes, but when I browse to the folders where the scripts are, it does not list any of them. As per the help here: Help
    What am I doing wrong?
    February 2, 2011
    Montreal/Paris
    830
    05:30 AM
    Packages are not definitions
    Think of packgages as snippet of codes all put together WITHIN a definition.
    The folder you should be pointing to is C:\ProgramData\Dynamo\Dynamo Revit\1.2\samples\en-US\Revit\DynamoPlayer. When you open that folder you will see .dyn that you can run with the Dynamo Player
    amoursol likes this.
    Member tuekappel's Avatar
    February 6, 2012
    Frederiksberg, Denmark
    322
    10:30 AM
    I would definitely wait a long while before i started using the Dynamo Player.
    ebow3d, start using vanilla Dynamo, creating your own graphs, applying them to projects. When you have constructed a graph that works well within a specific project, you can save it to a special folder, and use it only in that project.
    I see a danger in the player, because you can easily wreck an entire project running the wrong graph in the wrong project, potentially overwriting some or all important parameters for all objects.
    jmk likes this.
    Gold Coast
    2,602
    08:30 PM
    Quote Originally Posted by tuekappel View Post
    Good idea. Even running scripts from dynamo i always stc first
  1. Trouble with Formula
    By gioginnelli in forum Architecture and General Revit Questions
    Last Post: January 25th, 2017, 09:56 AM
  2. Replies: 0
    Last Post: November 19th, 2014, 12:45 PM
  3. Replies: 0
    Last Post: August 26th, 2013, 07:45 AM
  4. Railings trouble
    By Nushki in forum Architecture and General Revit Questions
    Last Post: April 24th, 2012, 10:47 AM
  5. trouble with BIM
    By sink69 in forum Out There
    Last Post: October 25th, 2011, 04:41 AM
Tags for this Thread
