Page 1 of 4 1234 LastLast
Results 1 to 10 of 34
Like Tree5Likes
Thread: Exporting and Importing from Excel
    Senior Member
    November 27, 2012
    577
    04:17 PM
    we have load of standard excel schedules we use (before revit) which i have produced in revit now.
    I want to create a dynamo script that uses are original excel sheets to push info into revit and vice versa
    is it possible and will I have to create a new script for each catorgory? ie Air termial schuedle (using catogory node in dynamo)
    Cheers
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,104
    12:17 PM
    You can use one Dynamo graph for all of your processing but you will need a set of nodes for each category.
    Senior Member
    November 27, 2012
    577
    04:17 PM
    What is that. Sorry I'm new to dynamo I've not actually created anything that exports to excel yet just seen something on YouTube
    August 9, 2011
    Louisville, KY
    6,104
    12:17 PM
    The Anatomy of a Visual Program | The Dynamo Primer
    In Dynamo, Nodes are the objects you connect to form a Visual Program. Each Node performs an operation - sometimes that may be as simple as storing a number or it may be a more complex action such as creating or querying geometry.
    Senior Member
    November 27, 2012
    577
    04:17 PM
    Brain wasn't in gear today. I know what a graph is DOH!
    So a new category node for each new category? Also there will be different parameters in the different categories
    August 9, 2011
    Louisville, KY
    6,104
    12:17 PM
    Pretty much. You will have a set of nodes for each schedule you want to process.
    Category: Air Terminal -> Extract Data -> Write Excel
    Category: HVAC Equipment -> Extract Data -> Write Excel
    The Write Excel could be combined if you are putting everything in one spreadsheet, otherwise you will need several of those as well.
    Senior Member
    November 27, 2012
    577
    04:17 PM
    so ive created this, but i cant get it to output anything excel?
    Attached Thumbnails Attached Thumbnails Exporting and Importing from Excel-revit-excel.jpg
    November 21, 2012
    London, United Kingdom
    612
    05:17 PM
    In theory what you have should work. What is the output of yourList.Create and List.Transpose nodes?
    I've whipped it up again using a little DesignScriptand it works fine.
    Attached Thumbnails Attached Thumbnails Exporting and Importing from Excel-revitforumquery_air_terminal.jpg
    Senior Member
    November 27, 2012
    577
    04:17 PM
    Quote Originally Posted by amoursol View Post
    that looks abit more fancier than mine with less nodes. this is my first attempt at doing a script. i added a watch node to the nodes to you mention and it just says 'function'?
    Attached Thumbnails Attached Thumbnails Exporting and Importing from Excel-capture1.jpg
    November 21, 2012
    612
    05:17 PM
    Have you hit run? If it says function it's not parsing any data.
  1. Revit Express Tools - Schedule XL - Importing Excel into Existing Revit Schedule (?)
    By theintern in forum Architecture and General Revit Questions
    Last Post: June 23rd, 2016, 05:00 AM
  2. Replies: 3
    Last Post: June 6th, 2015, 11:18 AM
  3. Exporting / Importing Search Sets
    By Drew in forum Coordination Tools
    Last Post: May 8th, 2015, 01:58 PM
  4. Importing Excel Files
    By Mr_Greg in forum Structure - General Questions
    Last Post: April 23rd, 2013, 08:59 PM
  5. Replies: 0
    Last Post: September 20th, 2012, 09:15 AM
