Results 1 to 9 of 9
Like Tree5Likes
  • 3 Post By josephpeel
  • 1 Post By ekkonap
  • 1 Post By ekkonap
Thread: Clockwork Nodes Are amamzing.....but
    Member ecraider's Avatar
    May 19, 2014
    Concord, CA
    87
    10:48 AM
    all of the sudden I do not know what is going on....
    My clockwork nodes are returning NULL...
    element.location is the first one that was broken.. but there are others too.
    I tried uninstalling all of my packages, then reinstalling starting with clockwork first... the test run... no bueno.
    ahhhhhh
    Anyone else out there see these same problems?
    November 21, 2012
    London, United Kingdom
    612
    11:48 AM
    What version of Clockwork are you using and what version of Dynamo? Andreas' has multiple iterations dependent on the Dynamo version out there.
    May 3, 2012
    1,396
    12:48 PM
    Yeah I had this problem too...
    I believe it is because the clockwork packages make a lot of use of the 'Return List or Single Item' node, inside the other nodes. This node was failing in lots of nodes after I upgraded to Dynamo 1.2 and just un-re-installing the clockwork package didnt fix the problem, because that node was not being overwritten and/or couldnt be found.
    I fixed it with a total reinstall from nothing, but some packages still havent been updated so just go for the ones that actually say Dynamo 1.2+
    While its great that Dynamo is being developed so quickly, the unreliability this causes is a real problem if you want to distribute your solutions within a company. So now I just insist everyone has the stable 1.2 version that comes with revit and doesnt update. I cut and paste the code out of the custom code blocks into 'python by string' nodes wherever possible too (Also a good way to fix old nodes), so people dont actually need the packages.
    amoursol, JWR and ekkonap like this.
    Senior Member ekkonap's Avatar
    May 23, 2011
    Netherlands
    576
    12:48 PM
    Quote Originally Posted by josephpeel View Post
    ...it is because the clockwork packages make a lot of use of the 'Return List or Single Item' node, inside the other nodes. This node was failing in lots of nodes ...
    +1
    I fixed it for pre-1.2 by looking up the 'Return List or Single Item' node and replaced it with my own version. Basically, if you use a list.Create and then List.Flatten by 1 tier. Does exactly the same thing.
    Or do what Andreas did in 1.2
    amoursol likes this.
    May 19, 2014
    Concord, CA
    87
    10:48 AM
    total re-install of Revit from nothing?
    May 19, 2014
    Concord, CA
    87
    10:48 AM
    total re-install of revit? or just Dynamo....
    May 23, 2011
    Netherlands
    576
    12:48 PM
    Just reinstall clockwork!
    May 19, 2014
    Concord, CA
    87
    10:48 AM
    Quote Originally Posted by ekkonap View Post
    Yeah..tried that twice already... did not work.
    May 23, 2011
    Netherlands
    576
    12:48 PM
    Quote Originally Posted by ecraider View Post
    Strange. Anyway, you can also track down where the 'turn into list' Node is stored and replace the python bit with the examples above. I found one installed here, for example. C:\Users\ena\AppData\Roaming\Dynamo\Dynamo Revit\1.2\packages\Clockwork for Dynamo 0.9.x\dyf
    Edit: suddenly confused which one was malfunctioning again, 'Return List or Single Item' or 'turn into list', or if the one was nested into the other. I am sure I only replaced 'turn into list' with my own version though.
  1. Can't Find Nodes.
    By pivoarch in forum Dynamo BIM
    Last Post: October 21st, 2016, 02:03 PM
  2. Resize nodes?
    By DaveP in forum Dynamo BIM
    Last Post: February 12th, 2016, 10:49 AM
  3. Replies: 0
    Last Post: May 4th, 2015, 12:45 PM
  4. Divided Surface Perimeter Nodes
    By BD Mackey in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: January 31st, 2015, 10:14 AM
  5. David Light: Dude! Where’s my Nodes?
    By David Light Blog in forum Blog Feeds
    Last Post: January 26th, 2012, 12:15 PM
Tags for this Thread
