Results 1 to 4 of 4
Like Tree1Likes
  • 1 Post By GMcDowellJr
Thread: Extract the Center point from Curve defining parameters
    Member ecraider's Avatar
    May 19, 2014
    Concord, CA
    87
    07:36 AM
    1) How do I filter out the value of the Center point from a list of defining parameters of a curve (an arc, model line)
    The only value I am interested is, is the center point.....
    Attached Thumbnails Attached Thumbnails Extract the Center point from Curve defining parameters-split-filter-list.png
    December 21, 2010
    Phoenix, AZ
    2,628
    12:36 AM
    Not elegant but you could convert this to a string and then search/filter by "CenterPoint."
    amoursol likes this.
    November 21, 2012
    London, United Kingdom
    612
    08:36 AM
    As Greg mentioned, here is an approach to that particular methodology. Not the most elegant solution, but one nonetheless.
    Attached Thumbnails Attached Thumbnails Extract the Center point from Curve defining parameters-string_split.png
    November 21, 2012
    612
    08:36 AM
    Or a completely Out-of-the-Box variant:
    Attached Thumbnails Attached Thumbnails Extract the Center point from Curve defining parameters-string_split2.png
  1. Replies: 0
    Last Post: September 24th, 2016, 12:01 AM
  2. Issue With Defining & Tagging Entire Room
    By colokate in forum Architecture and General Revit Questions
    Last Post: February 9th, 2015, 06:33 PM
  3. Revit OpEd: Insert using Auto-Center to Center
    Last Post: May 30th, 2014, 05:15 PM
  4. Defining room
    By Ashwini in forum Architecture and General Revit Questions
    Last Post: April 19th, 2013, 05:42 AM
  5. Replies: 0
    Last Post: November 28th, 2012, 11:49 AM
Tags for this Thread
