Results 1 to 1 of 1
Like Tree1Likes
  • 1 Post By jfmonod
Thread: Read from Excel fails because of spaces in file path
    March 18, 2011
    5
    03:38 PM
    Hi all,
    I found the solution to my problem while asking the question to post here, so i figured I'd post the solution anyway.
    Dynamo 1.2.1.3083. Looks like file paths with spaces are a problem. Added a code block with String.Replace(parsepath,"%20", " "); followed by the File.FromPath node. No more problem.
    Original solution post here: https://github.com/DynamoDS/Dynamo/issues/7429
    Thanks dbaldacchino
    Attached Thumbnails Attached Thumbnails Read from Excel fails because of spaces in file path-read-excel.png
    amoursol likes this.
  1. Export to DWF - File Names With no Spaces?
    Last Post: November 5th, 2015, 09:08 PM
  2. the file 'XX' could not be read, or is not a valid shared parameter file revit
    By Glen1980 in forum Architecture and General Revit Questions
    Last Post: November 14th, 2014, 09:42 AM
  3. Read-only file
    By kowen1208 in forum Architecture and General Revit Questions
    Last Post: February 19th, 2014, 09:15 PM
  4. Get my spaces to read archs room names?
    By domsib in forum Architecture and General Revit Questions
    Last Post: November 25th, 2013, 02:19 AM
  5. Revit OpEd: Importing AutoCAD File Fails
    Last Post: August 8th, 2012, 06:16 AM
