Results 1 to 2 of 2
Like Tree1Likes
  • 1 Post By Minsc
Thread: Dynamo for Rebar installation problem
    June 29, 2015
    5
    12:20 PM
    Hello everyone.
    I am trying to install package Dynamo for Rebar manually by placing the extract zip file in folder C:\Users\Minsc\AppData\Roaming\Dynamo\Dynamo Revit\1.2\packages and I have no result.
    When I examine package version 1.2 and older I see that folder Dyf in which custom nodes should be placed is empty. If someone can explain me the process of installing it manually step by step I would be very grateful.
    Thanks.
    June 29, 2015
    5
    12:20 PM
    Solved. It seems that windows was blocking some .dll files in bin folder. I just unblocked them in the properties... and apparently in some packages dyf folders are empty depending on how the custom nodes were created.
    amoursol likes this.
  1. problem after installation
    By biff in forum Architecture and General Revit Questions
    Last Post: February 23rd, 2016, 08:19 AM
  2. BIM & Beam: Dynamo for Rebar is Now Available
    By BIM & Beam in forum Blog Feeds
    Last Post: September 21st, 2015, 11:15 AM
  3. installation problem Revit architecture 2013 on window 8
    By henok in forum Architecture and General Revit Questions
    Last Post: October 15th, 2013, 02:19 AM
  4. Installation Problem whit Revit 2012
    By jmpimen in forum Hardware and Infrastructure
    Last Post: January 17th, 2012, 05:28 PM
  5. RAC 2012 installation problem.
    By JTB in forum Architecture and General Revit Questions
    Last Post: November 28th, 2011, 05:44 PM
