Donate Now Goal amount for this year: 3000 USD, Received: 2340 USD (78%)
Results 1 to 3 of 3
Thread: points from dynamo generating adaptive components in revit.
    October 18, 2016
    2
    09:44 AM
    Hi all
    I have an issue in dynamo/revit with generating adaptive components with 6 points from a point cloud trough dynamo.
    I have got it to work with 3 and 4 points in adaptive components but when I try to make a 6 points family it does not want to attach to the points.
    I tried to delete all geometry in the adaptive component family and only have the points and still did not want to generate.
    The point cloud is generated in grasshopper. and the tree is the same as my earlier points clouds to 3 and 4 adaptive point families.
    Does any one have experience with this kind off limitations?
    Attached Thumbnails Attached Thumbnails points from dynamo generating adaptive components in revit.-dynamo-points-error.jpg   points from dynamo generating adaptive components in revit.-adaptive-comp.jpg   points from dynamo generating adaptive components in revit.-grasshopper-list.jpg
    November 21, 2012
    London, United Kingdom
    586
    09:44 AM
    What is the list structure for the 6x points you are feeding in? Does it work when you isolate a single part of it (i.e try to place one adaptive component only)?
    February 2, 2011
    Montreal/Paris
    795
    03:44 AM
    Definitely gonna go with amoursol, something wrong in your list organisation if you can place a family manually
  1. Replies: 7
    Last Post: April 20th, 2016, 11:05 AM
  2. Adaptive components in Revit
    By KumarKapadia in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: March 4th, 2016, 08:48 PM
  3. BUG Adaptive Components relative Points Position
    By gaby424 in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: June 27th, 2015, 12:14 AM
  4. Replies: 0
    Last Post: September 16th, 2013, 02:15 AM
  5. Buildz: Dynamo: Placing Adaptive Components
    By Buildz in forum Blog Feeds
    Last Post: June 11th, 2013, 01:15 PM
Tags for this Thread
