Donate Now Goal amount for this year: 3000 USD, Received: 2460 USD (82%)
Results 1 to 4 of 4
Like Tree4Likes
  • 1 Post By amoursol
  • 1 Post By Iberkim
  • 2 Post By ScubaMan
Thread: Selection in Revit to Dynamo?
    Member Iberkim's Avatar
    June 24, 2016
    Denmark
    81
    09:14 AM
    I've been doing some basic scripts to ease my workload and I've often wondered if it possible, to use the selected objects in Revit as if it was selected by the node: "Select Model Element(s)" ?
    I would like to be able to just "tab-select" a string of lines and then run a script with those selected lines.
    November 21, 2012
    London, United Kingdom
    591
    08:14 AM
    Have a look at John Pierson's custom selection nodes in Rhythm
    1) Isolated Pick Model Elements
    2) Isolated Pick Model Elements (Ordered)
    There is also Dimitar Venkov's custom node in the Springs package:
    3) Springs.SelectElements(Ordered)
    They could be closer to doing what you desire!
    Iberkim likes this.
    June 24, 2016
    Denmark
    81
    09:14 AM
    Thanks alot. I'll look into it
    amoursol likes this.
    Member ScubaMan's Avatar
    July 6, 2015
    194
    12:14 AM
    The packages amoursol mentioned are probably what you are looking for.
    A work around for the build in node though is to (in Revit) select the elements you wish to select with dynamo and then "Isolate Selected" (HI is the hotkey). This will temporally hide everything not selected allowing you to use a selection box when you do it through dynamo.
    - - - Updated - - -
    amoursol and Iberkim like this.
  1. Revit OpEd: Pre-Selection and Selection Color
    Last Post: January 14th, 2016, 01:15 AM
  2. Replies: 0
    Last Post: November 16th, 2015, 01:15 PM
  3. Replies: 0
    Last Post: February 3rd, 2015, 01:15 PM
  4. Replies: 0
    Last Post: November 19th, 2014, 12:45 PM
  5. Replies: 0
    Last Post: August 26th, 2013, 07:45 AM
Tags for this Thread
