Results 1 to 6 of 6
Like Tree1Likes
  • 1 Post By DanielHurtubise
Thread: Scheduling Doors in LINKED model with Rooms in HOST model
    Member kamranmirza's Avatar
    January 12, 2011
    London, UK
    393
    12:52 PM
    We have multiple house units that repeat and so we are linking in house types and using them repeatedly for the different houses.
    Now, the doors are in the linked house type models and we have made the rooms in the HOST model to give them individually identifiable room numbers.
    Our door schedules use the "to room" parameter and the "room number" to identify the location of the doors. Revit doesn't allow the doors and rooms to be connected across linked models.
    Has anyone come across a solution using dynamo ?
    Thank you in advance.
    February 2, 2011
    Montreal/Paris
    804
    06:52 AM
    Steam Nodes can pull the Rooms from a link files but you wont be able to write it to the From/To Room parameter. I stopped using those a long time ago as they are not reliable(they won't update after the schedule as been created)
    once you have the Rooms then you can use Intersect to find the geometrical intersection. Might get a little tricky with doors but it works
    amoursol likes this.
    January 12, 2011
    London, UK
    393
    12:52 PM
    Thanks Daniel. They say that just giving a direction to the hungry is enough, they'll go feed themselves. Hopefully your direction will be enough for me
    January 12, 2011
    London, UK
    393
    12:52 PM
    January 12, 2011
    London, UK
    393
    12:52 PM
    And then this ?
    Topic: Geometry Intersect and Geometry DoesInterect not working | Dynamo BIM
    The end of the post has the solution ?
    August 13, 2014
    8
    01:52 PM
    there is this one:
    What Revit Wants: Collect Elements in Rooms Across Linked Files, and Write Room Data Directly to Elements or List to Excel
    but it seems so complicated to work, even dynamo keeps crashing very often when i open it and try to get my head around it
  1. Linked Model and Host File:
    By Ounces in forum Architecture and General Revit Questions
    Last Post: December 13th, 2017, 10:39 AM
  2. Linked Room Tags Overlapping Host Model Items
    By lizbrack in forum Architecture and General Revit Questions
    Last Post: May 10th, 2017, 08:04 PM
  3. Scheduling Linked Model Instances?
    By kylecaparella in forum Architecture and General Revit Questions
    Last Post: November 20th, 2015, 02:28 AM
  4. Copy rooms from Linked model.
    By Dominic in forum MEP - General
    Last Post: July 8th, 2014, 03:28 PM
  5. Printing host model with linked model
    By IMCarter in forum Structure - General Questions
    Last Post: May 11th, 2011, 01:00 AM
