Results 1 to 5 of 5
Thread: Bulk apply Shared Parameters to a Revit Family
    Member ryntau's Avatar
    October 11, 2012
    St. Louis
    389
    10:01 PM
    So every door family in our office has a dozen shared parameters in it. Everything in our template it setup fine, however whenever we create a new door, or use a door generated from a consultant / design architect.. it is lacking those parameters and we have to go through manually and generate each parameter one at a time for every door. Does Dynamo work inside the family environment?
    For instance, I'd like for a door to have a "Frame Rating" parameter.
    Discipline: Common
    Type of Parameter: Text
    Group: Identity data
    Instance Parameter
    or
    Frame Type
    Discipline: Common
    Type Parameter
    I've seen a few methods that circle this topic, but general consensus (at least in the past) is that it didn't work)... any suggestions?
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    5,605
    11:01 PM
    I know CTC BIM Manager Suite and Spectrum can apply parameters to families and either will pay for itself in no time. Not sure if Dynamo can do that or not...
    8,582
    10:01 PM
    CTC Family Processor (also included in the BMS as chad mentioned) does this, and also let's you store all the settings so you don't need to keep telling it what parameters. I have a ton of pre build settings files for just this purpose.
    Junior Member mfleming's Avatar
    January 31, 2014
    15
    11:01 PM
    Rushforth have got to be the best product out there for Shared Parameters, setting Parameter values & Formulas in batches.
    Oh and there are other tools in there too, but this is all I use.
    RushForth Projects
    Matt
    October 11, 2012
    St. Louis
    389
    10:01 PM
    I came across this plugin that seems to specifically address this, and for a much cheaper price. It was released a couple of weeks ago.
    Revit Add-Ons: Megara Shared Parameters Binder – Batch Add Shared Parameters to Families
  1. Apply shared parameters to a view
    By edmund in forum Architecture and General Revit Questions
    Last Post: August 20th, 2013, 07:32 PM
  2. Replies: 0
    Last Post: August 15th, 2013, 12:15 AM
  3. Copy shared paramters in bulk
    By cellophane in forum Architecture - Family Creation
    Last Post: June 26th, 2012, 04:27 AM
  4. Replies: 0
    Last Post: October 13th, 2011, 02:45 PM
  5. Hotfix – Apply material family parameters using the Paint tool
    By Munkholm in forum Architecture and General Revit Questions
    Last Post: October 11th, 2011, 07:34 PM
