Donate Now Goal amount for this year: 3000 USD, Received: 2527 USD (84%)
Results 1 to 2 of 2
Like Tree1Likes
  • 1 Post By amoursol
Thread: Changing Modeling Method with Dynamo
    January 18, 2013
    21
    07:58 PM
    Hello all,
    Thank you all for sharing your knowledge and helping people with your expertise.
    In my current model, the slab/floors are cutting the beams, hence the concrete volume of the beam is reduced.
    Kindly see the image which I uploaded.
    Question:
    Is it possible to change from "Current Situation" to "Desired Situation" for all the beams and slabs in the entire project at one go, using Dynamo.
    Hint; Revit command to be used: "Join Geometry" and "Switch Join Order"
    Thank you.
    Attached Thumbnails Attached Thumbnails Changing Modeling Method with Dynamo-modeling-method-question.jpg
    November 21, 2012
    London, United Kingdom
    593
    12:58 PM
    Hello ZoLaDo,
    Short answer: Yes.
    Long answer: It will require a little work.
    This functionality, to my knowledge, doesn't reside in the OOTB Dynamo nodes at present.
    You can have a look at the following post on the DynamoBIM forums if you want to try re-create the Python node.
    https://forum.dynamobim.com/t/automa...n-revit/1836/9
    Post back here when you've had a try
    ZoLaDo likes this.
  1. Replies: 0
    Last Post: January 11th, 2016, 07:26 AM
  2. Replies: 0
    Last Post: November 19th, 2014, 12:45 PM
  3. What Revit Wants: Changing Array Method after Creation
    By luke.johnson in forum Blog Feeds
    Last Post: December 18th, 2013, 12:15 PM
  4. Replies: 0
    Last Post: August 26th, 2013, 07:45 AM
  5. Replies: 0
    Last Post: September 19th, 2012, 06:15 PM
