Results 1 to 7 of 7
Like Tree5Likes
  • 1 Post By amoursol
  • 1 Post By Andrew P
  • 1 Post By rbcameron1
  • 2 Post By ScubaMan
Thread: Placing views on sheets
    Member Andrew P's Avatar
    February 19, 2011
    341
    07:09 PM
    This should be a straight forward process. Still, i'm getting a warning at the Sheet.ByNameNumberTitleBlovkandViews node. Can't quite figure out what's missing.
    Attached Files Attached Files
    November 21, 2012
    London, United Kingdom
    578
    06:09 PM
    Hello Andrew,
    That node in particular is relatively fickle. Most people are using a Python version that skips the need to place a view on a sheet to actually create them.
    Have a look at this link: https://forum.dynamobim.com/t/excel-...on-sheets/5307
    Good luck!
    cganiere likes this.
    February 19, 2011
    341
    07:09 PM
    Hi Sol,
    I tried to avoid Python scripts since I don't have any experience with Python Language, but this script is pretty straight forward and it worked. Thanks!!!
    amoursol likes this.
    Member rbcameron1's Avatar
    August 15, 2012
    USA
    191
    12:09 PM
    This is great! nice post and link!
    Member ScubaMan's Avatar
    July 6, 2015
    189
    11:09 AM
    Andrew,
    I just went through this myself. Check out these post that helped me get the job done.
    Create new sheet each time dynamo runs and place elements on sheet
    https://forum.dynamobim.com/t/create-new-sheet-each-run/7536
    Move View Titles (this cannot be done)
    https://forum.dynamobim.com/t/move-view-title/7332/2
    Placing views on a sheet
    https://forum.dynamobim.com/t/creati...ard-sheet/7262
    I would note that to make all of this work easily you may need to move your title-block to 0,0. My firms was about 11/512" off from this point making it impossible to get things to line up. I ended up having dynamo draw a line starting from 0,0 to somewhere else (Only way I could figure out how to move the title block accurately). Sucks if you want to incorporate into existing projects but everything now lines up perfectly.
    amoursol and cganiere like this.
    Member irneb's Avatar
    April 25, 2013
    Jo'burg SA
    344
    08:09 PM
    Quote Originally Posted by ScubaMan View Post
    An alternative way (without Dynamo or other programming) is to draw the lines in AutoCAD (where you can specific exact XYZ coordinates) then link the DWG onto the sheet using the Auto Origin to Origin option.
    December 17, 2012
    Stuttgart
    14
    07:09 PM
    Quote Originally Posted by irneb View Post
    Link this dwg into ur family to get the origin:
    https://1drv.ms/u/s!Ar9xxoyu3-ZhhfNvDQj-dHFofAWRTw
  1. Best Add-Ins for Sheets and Views?
    By wwdreamb in forum Architecture and General Revit Questions
    Last Post: October 17th, 2016, 03:54 PM
  2. Rotate plan views – not the views on the sheets
    By jh75 in forum Architecture and General Revit Questions
    Last Post: May 30th, 2013, 09:36 AM
  3. Placing imported cad upright in 3D views?
    By basilmir in forum Architecture and General Revit Questions
    Last Post: April 16th, 2013, 07:26 PM
  4. Sheets - Getting Views to fit?
    By domsib in forum Architecture and General Revit Questions
    Last Post: November 22nd, 2012, 10:11 AM
  5. Locking Views or Sheets?
    By wjnaim in forum Architecture and General Revit Questions
    Last Post: November 21st, 2011, 11:25 AM
