Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Like Tree5Likes
Thread: Renaming Materials - Only Working on Some Materials
  1. #11
    January 19, 2012
    325
    03:54 PM
    ...here is how this solution helped me to produce a script to export-edit-import...
    Renaming Materials - Only Working on Some Materials-edit-material-name-data.png
    cellophane and amoursol like this.
  2. #12
    April 12, 2019
    1
    08:54 PM
    Hi! It is possible to get the .dyn file of that please ?
    Thank you !
  3. #13
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,124
    04:54 PM
    Quote Originally Posted by cftrevizo View Post
Name:	Edit Material Name & Data.png
    Well that is pretty swanky. How does the "Use 'List 4' for Renaming" bit work?
  4. #14
    Member Bjorn_K's Avatar
    April 8, 2011
    Rotterdam, Netherlands
    316
    10:54 PM
    Suggestion:
    Using lists in Dynamo the export part this script can be simplified by a pretty big margin. (v1 without Code blocks, v2 with). Maintaining such a script and foreseeing having to add/remove properties in the export/import becomes a lot easier in the future then. Only the Id Node would be seperate from all the GetParameter Nodes (You can ask the Material Name that way as well)
    Renaming Materials - Only Working on Some Materials-material_properties_export_v1.png
    Renaming Materials - Only Working on Some Materials-material_properties_export_v2.png
    cellophane likes this.
  1. Renaming Families en masse
    Last Post: July 15th, 2015, 01:22 PM
  2. Subcategory renaming add-in out there?
    By Tim Waldock in forum Third party Add-Ins, API and R&D
    Last Post: July 13th, 2015, 11:51 AM
  3. renaming levels.
    By leetecture in forum Architecture and General Revit Questions
    Last Post: June 17th, 2013, 09:20 PM
  4. Phase Renaming
    By mfrietze in forum Architecture and General Revit Questions
    Last Post: October 7th, 2011, 09:00 PM
