Page 1 of 4 1234 LastLast
Results 1 to 10 of 34
Like Tree9Likes
Thread: Get name of the space/room where an element is with Dynamo
    August 29, 2015
    99
    08:45 AM
    Hi!
    Is it possible to get the name of the space/room where an element is with Dynamo?
    In Schedule it is possible to filter by "Space: Name" and/or "Space: Number" (Image1). Is it possible to do somthing similar in Dyname? Look at "Image2" there i tryied but i got nothing in my Watch-node.
    Best regards Engineer
    Attached Thumbnails Attached Thumbnails Get name of the space/room where an element is with Dynamo-image1.jpg   Get name of the space/room where an element is with Dynamo-image2.jpg
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,164
    04:45 AM
    amoursol likes this.
    Member johnp's Avatar
    March 24, 2015
    149
    02:45 AM
    Going to upload this to Rhythm right now too.
    Get name of the space/room where an element is with Dynamo-2016-01-27-15_16_51.png
    cellophane, amoursol and engineer like this.
    August 29, 2015
    99
    08:45 AM
    Thank you johnp! I tried Element.Space and it works fine with all elements exept with Cable Trays! Is there a way to make it work with Cable Trays?Get name of the space/room where an element is with Dynamo-cable-tray.jpg
    March 24, 2015
    149
    02:45 AM
    Hmm.. Seems possible, what would you expect it to do?
    Figure out if the cable tray is above the space?
    Or completely enclosed in the volume of the space?
    March 24, 2015
    149
    02:45 AM
    This version will determine which space the center point of a cable tray falls within.
    Get name of the space/room where an element is with Dynamo-cabletrayspace.gif
    August 29, 2015
    99
    08:45 AM
    To check the center point will work good in my case, so i think that node "CableTray.Space" will be my solution. I want to try it tomorrow, how do I get the CableTray.Space-node? Is it in a new Rhythm-package?
    March 24, 2015
    149
    02:45 AM
    I will publish this to Rhythm today. Are you on Dynamo 1.0?
    August 29, 2015
    99
    08:45 AM
    That would be great! Iam in Dynamo 0.9.2. but I have no problems to install 1.0 as well.
    August 29, 2015
    99
    08:45 AM
    Is it published? The latest I can se is from april.
  1. space&room or spase
    By UNikolai in forum Dynamo BIM
    Last Post: December 4th, 2015, 10:03 AM
  2. slanted wall vs space/room
    By Ning Zhou in forum Architecture and General Revit Questions
    Last Post: November 9th, 2015, 08:17 AM
  3. room separator line space tolerance
    By redmonki in forum Architecture and General Revit Questions
    Last Post: March 11th, 2014, 09:13 AM
  4. Find Room Element by Room Number?
    Last Post: September 17th, 2013, 05:22 PM
  5. Space / Room linking issue
    By Steven Thedens in forum MEP - General
    Last Post: December 7th, 2012, 09:03 PM
