Page 1 of 2 12 LastLast
Results 1 to 10 of 15
Like Tree13Likes
Thread: Dynamo
    September 26, 2011
    119
    11:24 AM
    Dynamo
    Guys,
    Anyone tried Dynamo yet?
    It seems like a Rhino for Revit and Free. (right?)
    recently I was told to do little research about it.
    If you happened to used this software, please let me know your experience with it.
    Thanks
    Lee
    May 8, 2014
    70
    07:24 PM
    November 21, 2012
    London, United Kingdom
    612
    08:24 PM
    Quote Originally Posted by leetecture View Post
    Guys, Anyone tried Dynamo yet?
    Quote Originally Posted by BoBMudd2 View Post
    It's akin to Grasshopper (Rhino) for Revit, yes. But also rather different. Dynamo also has very practical uses and the ability to query any model data which makes in more in line with BIM than purely a geometry creation engine. Have a read of the DynamoBIM forum as was rightly pointed out by BoBMudd2.
    July 15, 2014
    Salt Lake City
    26
    08:24 PM
    Youíre doing a disservice to Grasshopper by comparing it to Dynamo. Grasshopper is light years ahead of Dynamo and used by all major architectural, structural and engineering firms. Not only is it the best tool for form finding but more so for computational acoustic analysis, structural parametric design, egress, energy analysis, light analysis etc. design. The problem with Dynamo is not necessarily the way itís built, but the fact that itís built on Revit, which has huge modelling limitations. While Dynamo will continue to grow and one day may reach the same mature level as Grasshopper, Revitís development is as good as done and will suffer a slow death. This means that Dynamo will have to halt its development eventually, unless Inventor or any other modeling software gets hold of Dynamo.
    The users also plays a vital role in the development of Dynamo. Because Rhino users are generally designer or engineers seeking solution for the high end side of architecture, structural, acoustics, etc. grasshopper was develops for and by this segment of the market. They require a different set of tools. Dynamo which started off the same way as Grasshopper, doesnít have that segment of the market to further develop its tools in the same was Grasshopper did. The average Revit user is a draftsman working for a local firm on projects that donít require computational design tools. He rather have a proper working text tools in Revit, than a node that optimizes the amount off ETFE pillows on a double curved surface. , And because of that you can see that the Dynamo team have shifted their focus on bringing out nodes and workflow for local draftsman. Nodes to create levels with dynamo or nodes to renumber room using are examples of dynamo main area of focus.
    Member aristide's Avatar
    July 11, 2011
    Boston, MA
    74
    02:24 PM
    Quote Originally Posted by robertobatista View Post
    Not at all interested in arguing about one tool vs. another.. but the second part of this sentence made me LOL. What planet do you live on, where Rhino has a market share of 100%?
    amoursol likes this.
    Alex Cunningham's Avatar
    December 8, 2010
    Northern California
    3,567
    12:24 PM
    Moved to the Dynamo sub-forum.
    January 18, 2014
    122
    02:24 PM
    I don't know if you just don't know what you're talking about or if you just haven't used Revit enough to know that any modelling limitation in Revit is a minor one. I have yet to encounter any form that could not be modeled in Revit. While modelling complex forms can be difficult to accomplish, it can still be done, and at the same time maintain a parametric relationship to regular building elements and be used to collect data needed for construction and documentation.
    Again, I think you are misinformed about Revit, it's users and their level of competency. I am an average user of Revit, and as an Architect, I use it for a wide range of projects. Does Revit need better text tools? Yes. Can Dynamo help create levels or renumber rooms? Again, yes, because in order to be an actual Architect, you need to be able to produce useful drawings. And I don't care who you are, a timesaver is helpful to everyone, including high-end designers. If you want to see some of the more exciting nodes in Dynamo, check out Zach Kron's buildz blog.
    Autodesk Scott D Davis's Avatar
    March 5, 2011
    Southern California
    653
    12:24 PM
    sorry robertobatista, but you have your "facts" wrong. Dynamo is built as a completely stand alone application, that just happens to have the capability to hook into the Revit API. It can also be hooked to Rhino. And Excel. And Inventor. And other applications. In fact, Case, Inc. has developed Rhynamo, that can take a Rhino model through Dynamo and build native Revit geometry.
    For those that actually use grasshopper and have seen/used Dynamo, they would argue that while grasshopper is "older" in terms of development and therefore capabilities, to call them "light-years" apart would be a disservice. Because Dynamo is open sourced, many Grasshopper users are taking their favorite nodes in grasshopper and creating similar nodes and capabilities in Dynamo, and then making them available to all.
    amoursol, cellophane and cpercer like this.
    Orlando, FL, USA
    3,093
    03:24 PM
    ... And because of that you can see that the Dynamo team have shifted their focus on bringing out nodes and workflow for local draftsman. Nodes to create levels with dynamo or nodes to renumber room using are examples of dynamo main area of focus.
    Wow. You obviously have not seen what some people have done with Dynamo.
    July 15, 2014
    Salt Lake City
    26
    08:24 PM
    Quote Originally Posted by Scott D Davis View Post
    Dynamo has capabilities of creating geometry that can't translate into real Revit geometry. Take for instance a long standing wish, the ability to create 3d fillets, something pretty much all 3d (BIM) modelling software can do. Not so long ago someone released a node that can make 3d fillets to any geometry in Dynamo which is great. This translates beautifully into Inventor or even Rhino, but in Revit it imports as dumb .sat geometry which isn't editable (unless you use dynamo). The sat geometry acts like any imported 3d CAD geometry with all the visibility issues and un-schedulability and not being able to ad information to the geometry.
    We can safely say that Revit will not improve its modelling tools for the remainders of Revit' life. There is no doubt that the combination of Inventor and Dynamo will be great, but will dynamo still be a computational design tool for Revit in a year or two when Dynamo drastically continuous to expand and improve or will it end up being just a tool to extract data out of Revit?
    It would be interesting to see examples of firms using Dynamo for things they've done previously with Grasshopper. So far I’ve only seen sample of geometry created or data extracted from Revit but nothing on a real projects. Even at AU, ironically firms showed how they utilize Grasshopper on real projects but not Dynamo. I’ve asked around why they don't use Dynamo, they all reply the same; Why use dynamo if they can use Grasshopper for computations design.
  1. What is dynamo?
    By Simply Complex in forum Blog Feeds
    Last Post: January 30th, 2015, 04:15 PM
  2. Replies: 0
    Last Post: November 19th, 2014, 11:45 AM
  3. Dynamo 0.7 ???
    By bt.comm in forum Dynamo BIM
    Last Post: October 11th, 2014, 08:13 AM
  4. Dynamo 0.7 ???
    By bt.comm in forum Architecture and General Revit Questions
  5. Replies: 0
    Last Post: August 26th, 2013, 07:45 AM
