Results 1 to 7 of 7
Like Tree5Likes
  • 1 Post By tuekappel
  • 2 Post By amoursol
Thread: Replacing Shared Parameters globally
    November 21, 2012
    London, United Kingdom
    612
    11:58 PM
    Morning all,
    Just going to share a very simple script I toyed around with this morning. It simply queries parameters of a field (In this instance 'Sheets') and inputs data into those parameters, on sheets, globally.
    As such it should only be used for parameters that requires consistent data across all sheets. Be mindful of this
    In this instance I'm doing it individually as I haven't quite worked out how to get a list.create result working yet (Cross product puts in the 'date' value in all fields).
    Replacing Shared Parameters globally-dynamo_script_sheet_parameter_replacement.jpg
    Any tips on the list.create next step on this front? After I have a list, I've tried turning my array into a string (Fails) and using all lacing types in the 'Element.SetParameterByName' field. Bear in mind I'm just playing too! Below showcases where I got to.
    Attached Thumbnails Attached Thumbnails Replacing Shared Parameters globally-dynamo_script_sheet_parameter_replacement.jpg
    Member tuekappel's Avatar
    February 6, 2012
    Frederiksberg, Denmark
    336
    10:58 PM
    I think; as soon as you use an indexed list of parameters, Dynamo looks at the sheets and sets the parameter#1 of sheet#1, then parameter#2 of sheet#2....
    So you need Cross Lacing in Element.SetParameterByName
    Arrghh, no! Wrong! -I see the problem.....
    -Somehow you need to get into sublists, for both sheets and parameters.
    I'll have to study sublists, be back in a couple of days :-)
    amoursol likes this.
    November 21, 2012
    612
    11:58 PM
    Quote Originally Posted by tuekappel View Post
    I've been helped on Dynamobim.org (Thanks Andreas!), the solution is quite easy in the end.
    All that is needed is a 'List.Combine' as illustrated below. Success!
    Replacing Shared Parameters globally-dynamo_script_sheet_parameter_replacement3.jpg
    February 6, 2012
    336
    10:58 PM
    OK, i didn't know you could put an operand in the end of the SetParameter node. Interesting.
    I managed to solve the problem otherwise, too, via sublists. It took quite some trial and error, but i'm learning, slowly....
    Attached Files Attached Files
    February 6, 2012
    336
    10:58 PM
    Now you got me thinking, Amoursol.....
    I tried to filter the list of sheets, based on their Sheet Name ( could have been any parameter), so that only the sheets containing "test" in their Sheet Name gets their values replaced:
    I thought it could come in handy, since you have a lot of sheets to rename, and i guess you'll have to discriminate at one point?
    Alex Cunningham likes this.
    November 21, 2012
    612
    11:58 PM
    Very handy thank you! I'll filter by input field contains an empty string ( ""; ) or something. I also didn't know about the operand at the end - which is a bit of a game changer even at my early stages. So much epicness to learn though.
    November 21, 2012
    612
    11:58 PM
    As an addendum, concatenate with a Code Block is also useful in my particular instance.
    Here is what I did in order to pull two lines of 'Sheet Title' into one in the 'Project Browser'. I have also incorporated your filter Tuekappel.
    EDIT: Attached Thumbnail is the simple version, attached image is the Filter version.
    Replacing Shared Parameters globally-dynamo_script_sheet_parameter_replacement4.jpg
    Attached Thumbnails Attached Thumbnails Replacing Shared Parameters globally-dynamo_shared_parameter_code_concatenate.jpg
    tuekappel and Alex Cunningham like this.
  1. Shared Parameters or Project Parameters?
    Last Post: November 7th, 2013, 02:14 PM
  2. Replies: 0
    Last Post: August 15th, 2013, 12:15 AM
  3. Import shared parameters into an existing shared parameters file
    By Ree in forum Architecture and General Revit Questions
    Last Post: January 14th, 2013, 09:34 PM
  4. Shared Parameters
    By cve60069 in forum Structure - Family Creation
    Last Post: June 11th, 2012, 01:50 PM
Tags for this Thread
