Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Like Tree25Likes
Thread: Dynamo Starting Guide
  1. #11
    March 20, 2012
    21
    06:31 PM
    Question(s), how does Dynamo actually work? I mean, do you have to create an object/linework/etc. in each Revit project? Is the 'code' saved somewhere & if so, where? If it is saved, does it get inserted like a family? Can you place your code in a template to be used over & over?
    What do YOU use Dynamo for (some explanatory examples would be excellent)?
  2. #12
    Member cganiere's Avatar
    January 5, 2011
    Orange County, California, USA
    204
    10:31 AM
    I have used Dynamo to upgrade Revit families from 2017 to 2018. You set the directory and hit start.
  3. #13
    Member irneb's Avatar
    April 25, 2013
    Jo'burg SA
    350
    08:31 PM
    Quote Originally Posted by Hangman View Post
    There's an addon in Revit which runs inside a normal DotNet environment (like nearly all other addons do). This creates the Dynamo environment which loads a text file (XML) which describes the tiles you've placed and the connections between them. This environment runs through those tiles' actions and then performs it on the current Revit session.
    Nope, Dynamo can create the obj/line/etc. for you, or it can modify existing stuff.
    It is saved as a text file (a XML file listing the tiles you've placed in the dynamo editor and the connections between them).
    No it doesn't form part of the RVT / RFA file. It's a separate DYN or DYF file - see previous point.
    Definitely! Because it's in separate files you can copy these anywhere. Open then save-as something else as well as rename them. You can also copy-paste tiles between DYN (Dynamo scripts) and DYF (custom dynamo tile definitions).
    In addition you can package DYF files as a set of stuff to import into Dynamo so others can use it. There's even an online share so you can publish it on the Dynamo sharing site so others across the world can make use of the same. There's already 1000s such published there by various people who were kind enough to share their work.
    Quite a diverse set of reasons. My very first use was to find duplicate parking bays on ramps. Another was to model a sloping curving balustrade made of steel slats. Many a time I use it to model curtain walls with randomized patterns. Then also I've used it to set panel marks over many large curtain walls so they schedule in some sort of consistent manner (i.e. from left to right / top to bottom - instead of just random after some changes). Same sort of thing about renumbering doors / windows after adding new stuff into a building.
    Those are just the types of things I've personally done - the things I can remember off the top of my head. Others could also chip in. Or you could search through other posts in this forum seeing what others are asking for or sharing. Also look at the DynamoBim site - they've got lots of samples of things people have used Dynamo for.
    amoursol likes this.
  1. Replies: 0
    Last Post: November 19th, 2014, 12:45 PM
  2. Replies: 0
    Last Post: August 26th, 2013, 07:45 AM
  3. starting a project
    By arch87 in forum Architecture and General Revit Questions
    Last Post: October 31st, 2012, 03:14 AM
  4. Formula starting with '='?
    By byork in forum Architecture and General Revit Questions
    Last Post: October 30th, 2012, 10:32 PM
  5. Starting View
    By chris.macko in forum Architecture and General Revit Questions
    Last Post: May 25th, 2012, 09:56 AM
