Page 1 of 2 12 LastLast
Results 1 to 10 of 14
Like Tree4Likes
Thread: multiple versions of navisworks
  1.    #1
    Member evan.dodds's Avatar
    December 29, 2014
    Calgary, Canada
    205
    12:13 PM
    Is it necessary to have multiple versions of navisworks installed on your computer, or do you only need one (the most current?).
    My office doesn't really (read practically never) use navisworks so I am fairly unfamiliar with how it works. I've always had each version of navis installed to match which versions of revit we have installed on the computers for my office. It looks like the only thing that I need is the export utility for each navis version and then I can just open the nwc file in whatever version of navis?
  2.    #2
    January 17, 2011
    2,046
    01:13 PM
    Most current is all you need.
    -TZ
    evan.dodds likes this.
  3.    #3
    Member HansLammerts's Avatar
    April 22, 2011
    466
    06:13 PM
    Highly unusual for Autodesk sake. For as long as it exists.
  4.    #4
    Mr. Revit OpEd
    2,910
    11:13 AM
    Quote Originally Posted by HansLammerts View Post
    Perfect example, you're not answering a question...just throwing shade at Autodesk. Why do you even spend time here? Is that what you enjoy, casting shade? Don't you have more productive things to do?
    DavidLarson and tzframpton like this.
  5.    #5
    10,277
    01:13 PM
    Actually, to properly answer your question, there are a few additional things you might want to look in to:
    1. What licenses types you have
    2. How close you are to hitting your license count limits
    The reason being: The older Suite Licenses, each VERSION you had opened pulls an additional license. So if you are in Revit 2019 and Navisworks 2020, you are consuming two licenses. Meaning, if you have 50 people, and 50 licenses, youll run out before everyone gets a license. For those offices, i have (sadly) seen some firms keep ALL of the platforms on the version that user currently needs, on the machines (which is a terrible way to manage, second in lousiness only to putting ALL versions of ALL platforms on every machine, which- youll find- eats up a Hard Drive stupid fast). Basically their rules are: If your project is in Revit 2018, then you use Autocad 2018 and navis 2018... if you are in 2020, you use navis 2020 and AutoCAD 2020).
    The new Collections licenses are way better about it, at least, when using the Named Account licensing: if a user is signed in on the machine, it doesnt matter what they open (from the same collection). So revit 2020, Revit 2019, AutoCAD 2018, etc. It doesnt penalize.
    There have occasionally been some funky things with upgrading NWF's to the newer versions, but not many, and not often. As Tannar said, we only keep the latest version of Navis on our machines (because the licensing thing isnt an issue here).
  6.    #6
    April 22, 2011
    466
    06:13 PM
    Quote Originally Posted by Steve_Stafford View Post
    Just pointing out every software has a lifetime circle. That's all. In case of Navisworks i think we are near the end of it. Don't take it so personal. Don't bite my head of right away.
  7.    #7
    Mr. Revit OpEd
    2,910
    11:13 AM
    Just pointing out every software has a lifetime circle. That's all. In case of Navisworks i thing we are near the end.
    No, if you were you would have written that instead. Useless...
    HansLammerts likes this.
  8.    #8
    April 22, 2011
    466
    06:13 PM
    The question was already answered. So yes, anything that comes next is either useless or to debate further.
  9.    #9
    10,277
    01:13 PM
    Hey- I just want to make sure: can we get a moderator or an admin to clarify: Does this mean once a thread is answered, its okay to let the posts that come after the answer be a free for all about whatever we want? Asking for a friend.
  10.    #10
    December 29, 2014
    Calgary, Canada
    205
    12:13 PM
    Definitely more concerned about Hard Drive space as our current machines only have 256GB SDDs on them... Since I've never really used Navisworks (as I stated, our office hardly uses Navisworks), I've just thrown all versions on there to match what we've installed for Revit as I assumed file versions functioned the same way. Licensing is not an issue since we are aligned with the per User/Computer licenses (we don't do named accounts, yet...).
  1. Revit - IFC versions
    By MARIA1993 in forum Architecture and General Revit Questions
    Last Post: July 19th, 2017, 06:43 AM
  2. New IFC versions in Revit.
    By sabari2504 in forum Architecture and General Revit Questions
    Last Post: April 20th, 2017, 07:31 AM
  3. Update Versions
    By Gabriel Black in forum MEP - General
    Last Post: September 30th, 2014, 07:46 AM
  4. convert Revit multiple 3D views to Navisworks views
    By Ning Zhou in forum Coordination Tools
    Last Post: April 19th, 2014, 03:50 AM
  5. Older versions
    By rubensjr1 in forum Architecture and General Revit Questions
    Last Post: June 27th, 2013, 03:00 AM
