Results 1 to 5 of 5
Thread: Point Cloud Coordination
    November 12, 2012
    Bangalore
    39
    12:29 AM
    Hello,
    First of all I am very new to point cloud in Revit, and my question is how accqure or use same coordinator system in Revit as in the received point cloud data.
    This requirement is because in Recap pro, I have link both the point cloud file and also the NWD(extracted from Revit).
    https://help.autodesk.com/view/RECAP...7-DE6BC7D66759
    Can anyone please help me out on this?
    Sent from my Mobile Device using Tapatalk
    December 21, 2010
    C.LONDON
    4,382
    07:59 PM
    Quote Originally Posted by amarkrish108 View Post
    I'll start with moving your query to it's own dedicated thread in a more appropriate place.
    Member aperte's Avatar
    August 9, 2011
    67
    11:59 AM
    Unfortunately, there is no 'easy button' for this. Your process will have to be either to reset the origin point in the ReCap file (see: https://knowledge.autodesk.com/suppo...4828D-htm.html ) or the Base Point in Revit (which in this case I would not recommend, because there are already other programs coordinated to that Revit system).
    November 12, 2012
    Bangalore
    39
    12:29 AM
    Quote Originally Posted by aperte View Post
    Thanks aperte,
    Sorry for the delay in replying.
    We tried as per your suggestion, but if we move the origin in recap, won't that coordinator is changed permanently, and once we submit back the client will he have a shared coordinates issue as he would be using the old coordinates.
    I have another concern, if I move the origin in Recap, then how can I determine its coordinator value in Recap to apply in Revit?
    Member HansLammerts's Avatar
    April 22, 2011
    451
    06:59 PM
    Export your rvt to a dwg in shared coordinates and let Autocad do the geometry checking. That is my prevered workflow. Use xref methodology to update your model. Save views and use clipped and copied portions of pointcloids. All within Autodesk subscription without addition software or goofy revit addons
  1. BIM to point cloud
    By cbaze in forum Architecture and General Revit Questions
    Last Post: January 12th, 2018, 03:37 PM
  2. Point Cloud
    By gizemge in forum Architecture and General Revit Questions
    Last Post: August 26th, 2015, 10:59 AM
  3. point cloud
    By ram_123 in forum Architecture and General Revit Questions
    Last Post: May 21st, 2013, 09:47 AM
  4. Replies: 0
    Last Post: June 15th, 2012, 08:17 AM
  5. Replies: 2
    Last Post: December 16th, 2010, 01:07 AM
