Results 1 to 2 of 2
Thread: Autodesk Glue Exporter
  1.    #1
    Member koolair's Avatar
    July 31, 2014
    238
    11:28 PM
    Is there a way to limit the number of views that you can export to Glue?
    I have to scroll through piles and piles of views just to check three views.
    This is such a pita.
  2.    #2
    January 17, 2011
    1,969
    10:28 PM
    Not that I know of. I drag the corners of the Window and make it really tall so the scrolling isn't too bad. I'll Collapse a few of the huge View lists but other than that, it's gotta scroll.
  1. Autodesk STL Exporter 2018
    By TheRevitKid in forum Architecture and General Revit Questions
    Last Post: September 7th, 2017, 02:57 PM
  2. BIM 360 Glue
    By Cyus in forum Coordination Tools
    Last Post: August 19th, 2016, 03:29 PM
  3. Autodesk BIM 360 Glue
    Last Post: January 16th, 2015, 08:09 PM
  4. Replies: 0
    Last Post: October 9th, 2012, 12:45 PM
  5. Inside the System: Autodesk Revit IFC Exporter Code
    By Inside the System in forum Blog Feeds
    Last Post: September 13th, 2011, 08:20 PM
