Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Like Tree9Likes
Thread: Revit Assembly to Navisworks
    Senior Member ekkonap's Avatar
    May 23, 2011
    Netherlands
    577
    09:17 AM
    A client wants to use our model in Navisworks, and wants to be able to select a whole Window. Our Revit Windows are made with Nested Shared Components. That means that if the client selects the Window in Navisworks, the selected element is only the windowframe, without glass panels.
    I tried puting the Window main element and its Nested Shared Components into an Assembly to remedy the problem, but the client reported no difference.
    A similar issue was described in 2011 in the link below (apparently the issue was logged as an 'Enhancement Request'), any new insights since then?
    https://beyonddesign.typepad.com/pos...ssemblies.html
    Orlando, FL, USA
    3,093
    03:17 AM
    Hello. I made a test about this. A window family with nested shared frame and nested glass panel. I export to .nwc. Open the .nwc in Navisworks Manage. I am able to see the window with its nested parts, I am able to select the window as a whole, I can select its parts individually, and I can quantify the number of windows. I can share the test files if that helps.
    ekkonap likes this.
    10,127
    02:17 AM
    It has to do with how they have Selection Resolution set in Navisworks. If its on Last Object, it will always grab the Nested Shared Components.
    ekkonap likes this.
    May 23, 2011
    Netherlands
    577
    09:17 AM
    Thanks for the quick feedback! I'll let you know how it turns out, probably after the weekend.
    December 21, 2010
    C.LONDON
    4,378
    08:17 AM
    To counter/accommodate this in both our Revit (id'ing) & Naviswork (selecting) workflows we've employed pushed-down instance and type properties from parent to all children (and grand-children) - but that'd involve some overhaul of content -and it adds some compute-weight wait some might not be happy about.
    May 23, 2011
    Netherlands
    577
    09:17 AM
    Instead of rebuilding our library for one of our clients, I'd consider a Dynamo script that just writes all that data.
    Snowy, how far do you take this? Does the glass contain all info of the frame?
    And out of curiosity, how do you push data from the nested component back to the main component? Or do your nested components not have Type properties?
    10,127
    02:17 AM
    Dynamo can pull from Nesteds up to Parents using SuperComponent Node and SubComponent Node. Can push down that way as well.
    December 21, 2010
    C.LONDON
    4,378
    08:17 AM
    Quote Originally Posted by ekkonap View Post
    Same, were it not for the fact these have been in the running long before Dynamo came around!
    No, only IDs and a few geographical properties, that we marry up in Excel.
    We don't - but Aaron's answer has you sorted there.
    May 23, 2011
    Netherlands
    577
    09:17 AM
    Unfortunaletly, my client reports not being able to select the assembly, with any selection setting (last object, first object, geometry I think he called them). I'm not quite ready to give up though, you all seemed quite confident. Link to my R2019 file below (<10mb) from ftp. @Alfredo, can we have a look at your test file?
    download
    Orlando, FL, USA
    3,093
    03:17 AM
    ... @Alfredo, can we have a look at your test file?
    There you go: this is an .nwd file with some saved search sets, one to find all windows and another one to find only the window type that contains nested shared parts.
    Attached Files Attached Files
    Last edited by Alfredo Medina; January 15th, 2019 at 04:24 PM. Reason: *saved search sets
    ekkonap and Andres Franco like this.
  1. Replies: 0
    Last Post: September 23rd, 2016, 04:15 AM
  2. Revit Assembly
    By ashwinghanta in forum Architecture and General Revit Questions
    Last Post: March 19th, 2015, 01:47 PM
  3. Revit Families or Assembly
    By charlton1. in forum Architecture - Family Creation
    Last Post: October 31st, 2014, 02:03 PM
  4. What is Assembly Code and Assembly Description?
    By BenMiller in forum MEP - General
    Last Post: June 4th, 2014, 03:24 PM
  5. Revit OpEd: Cool Lego Assembly Line
    Last Post: September 20th, 2012, 03:15 PM
