Results 1 to 1 of 1
Thread: Navisworks export to KML file
    October 16, 2016
    397
    11:40 AM
    Hello all,
    Could someone explain me what exactly I need to do in order to export a model from Naviswork to goole map pro?
    In the KML Options which coordonates I should put in the Origin Tab (Google Earth , Navisworks)?
    In the Revit model I have used Swiss Coordinates so when I go to Origin Navisworks Pick I have for example X: 1135600.9663 m Y: 2535936.4876m Elev: 200m
    In the Google Earth coordinates I should convert these values in degrees?
    Any guidance will be useful!
    Thank you
  1. Navisworks Export
    By TFuller in forum Coordination Tools
    Last Post: July 8th, 2015, 03:00 PM
  2. Replies: 0
    Last Post: January 3rd, 2015, 11:45 PM
  3. Export to navisworks?
    By nick_h in forum Coordination Tools
    Last Post: November 12th, 2013, 07:31 PM
  4. Export to navisworks?
    By nick_h in forum MEP - General
    Last Post: September 25th, 2013, 01:11 PM
  5. Problem in dwg file import Revit then export gbXML file
    By roczhu in forum Architecture and General Revit Questions
    Last Post: September 2nd, 2012, 11:47 AM
