Results 1 to 3 of 3
Thread: Navisworks tolerance in clash detection tests
    October 16, 2016
    391
    12:30 AM
    Hello all,
    I have a difficulty to understand well the clash types and tolerance in Navisworks. So, I need some explanations..
    In the first image I run a Hard Type Test with 0.00 tolerance , so I expect to see all the ovelaps that have distance more than 0.00m (Is this thought correct?)
    I cannot understand how the distance -0.85 arise?
    In the second and third Image I run a Clearance Test with a Tolerance 0.13, so I expect to see all the elements that have maximum distance 0.13m (Is this thought correct?)
    I cannot understand what these negative distances mean (2nd image -0.38m)
    and again how the distance is calculated (image 3)
    Thank you in advance!
    Attached Thumbnails Attached Thumbnails Navisworks tolerance in clash detection tests-hard-0.0.png   Navisworks tolerance in clash detection tests-clearance-0.13-_-2.png   Navisworks tolerance in clash detection tests-clearance-0.13.png
    February 9, 2017
    2
    07:30 AM
    A clash with distance -0.85 means there are two points from objects which have clashed or overlapped by 0.85m
    October 16, 2016
    391
    12:30 AM
    Quote Originally Posted by Gedward View Post
    Thank you for your answer!
    So the minus '-' does mean that there are more than two points that provocate the clash?
    What about the distance? I cannot understand why the distance is 0.85m as the thickness of the floor is 0.13m.
  1. Clash Detection in Revit 2017 and Navisworks 2017 + plugin BIMONE
    By archsaad in forum Architecture and General Revit Questions
    Last Post: February 10th, 2018, 09:23 AM
  2. Replies: 8
    Last Post: April 7th, 2017, 12:07 PM
  3. Clash Detection as a Service
    By chompi0n in forum MEP - General
    Last Post: September 25th, 2014, 04:48 PM
  4. Navis Clash Detection?
    Last Post: December 15th, 2013, 09:45 PM
  5. What Are You Using For Clash Detection?
    By renogreen in forum Coordination Tools
    Last Post: May 14th, 2012, 06:29 PM
